Tobacco Decals Options
GT40Lover
#1 Posted : 25 November 2024 15:05:33
Rank: Newbie
Lotus 97T Tobacco Decals
The tobacco decals supplied with the build have a thick overcoat film which is very noticeable when applied and detracts from the finish. I have found a simple way of removing this film, leaving just the printing, and the end result is much nicer to look at and is almost as good as the factory printed lettering. Here are the steps:
1. Soak the decal, slide it off into final position, blot it to remove the water.
2. Apply Solvaset or Micro Sol liberally to the decal, this is important to ensure the decal is well stuck to the part, especially if the decal is on a 'carbon fiber' part. Let it work for 5 minutes and then gently dab down the decal surface with a soft paintbrush to expel air bubbles. Leave to harden overnight.
3. The next day (not much longer as the overcoat film will age harden), dip a soft paintbrush in Humbrol enamel thinners or good quality white spirit (like Rustins) and wet the entire decal. Keep wetting the decal for about 5 minutes. This will soften the overcoat film. Try gently rubbing an edge of the overcoat film with the soft part of your finger (not your fingernail) and see if the overcoat film rubs off. If not, apply more white spirits and wait a little longer. The overcoat film should rub off easily and completely leaving the coloured print. Gently wipe over the coloured print with a soft piece of tissue dipped in enamel thinners to remove any remaining residue.
Caveats: This technique works especially well on kit surfaces that are painted gloss, and 'carbon fiber' surfaces that have a glossy sheen. Some 'carbon fiber' surfaces have a semi-gloss sheen and with the latter you need to be more careful as the enamel spirits can remove the paint layer if rubbed too enthusiastically. But if you stick to the above instructions you should have no problems. As always, try it out first. And the good news is that the remaining coloured print seems durable, but as always try not to handle it. Brave modellers can always overcoat their parts with clear lacquer. BTW I have tried other solvents on the overcoat film and white spirits is the only one that worked.
If you eat today, thank a farmer.
If you eat from your table, thank a trucker.
If you eat in peace, thank a veteran.
#2 Posted : 25 November 2024 17:16:22
Hi GT40Lover, BigGrin
Thanks for your input, first of all.
However there are a couple of things to point out.
1) As a newcomer first post, if you resize your pictures to 650 pixels width they will show and not be downloads. Lots of people won`t download items from an unknown source.
2) This is for anyone trying the method described in post #1.
Should this method fail (through who evers fault) then Deagostini will not replace parts without photographic proof of the problem and if decided the issue is modeller instigated then parts will not be replaced free of charge and maybe not at all.
I feel it would be remiss of me not to point out the above point #2.
(Derek) Admin
GT40Lover
#3 Posted : 25 November 2024 19:31:37
Rank: Newbie
Hi Derek,
Thanks for your advice and point no. 2, much appreciated. Before I try to post a resized photo, could you please let me know if I am actually allowed to post a tobacco decal photo on the forum (or indeed anywhere else!)? I have only just noticed from a quick search they are usually censored on the forum. Thanks.
Vaughan
#4 Posted : 25 November 2024 19:46:55
GT40Lover wrote:
Hi Derek,
Vaughan
Hi Vaughan,
Please note that the decals of the Lotus 97T are not allowed to be shown on the forum. This is a ruling from Deagostini not directly from this forum.
(Derek) Admin
Senna64
#5 Posted : 10 April 2026 21:44:13
Rank: Member
For folk wanting a simpler, reliable process, this is it:
https://www.instagram.com/reel/CzwjOZ0Masn/
Just wait a few hrs after decal is placed to remove the carrier film. Works every time flawlessly
This page was generated in 0.385 seconds.
