 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Cheers Mark. Stage 33, right hand exhaust and crankcase Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
Keep it coming. It's great to see another one of these being built. Looking really good.
Cheers Roy. Stage 34 lower crankcase and alternator. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 35, distributor and plug leads. I glued both ends of each lead as they were a little on the loose side. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Pro Groups: Registered
Coming along nicely. Like the yellow leads. They show up well against the black and silver. Andy.
Cheers Andy. The leads will be yellow on the real car. I reckon the colour is a nod to Renault Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 36. As expected, very fiddly! Intakes connected, throttle and fuel lines fitted. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 37, left side waste gate fitted Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 38 done, right side waste gate. Waiting on pack 9 now. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Another nice update. Keep them coming.
Cheers Roy👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Looking good Steve, very nice work. Mark Regards Markwarren (Mark) Admin
Cheers Mark👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Pack 9 has arrived but unfortunately it is missing stage 43. They have sent 2 stage 39's🤦♂️. I have emailed them Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 43 is here now so I can crack on with pack 9. I'll need to get a move on as pack 10 is in the post. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 39, alternator pulley and belt. Be careful with these vp screws, they are really tight. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 40 done. Crankcase parts. A little tip, step 40-4 and 5, i found it easier to thread the wire through from the tps end and out of the back of the engine and then attach the wire to the left cylinder bank rear cover. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
A great update. Nice to see another one coming together.
Cheers Roy. Stage 41 done, oil pump. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 42, front of engine. Oil pipe, distributor belt, lower pulley mount, etc. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
