Motor Modeller - F1
Lotus 97T
Lotus 97T Discussion Area
LOTUS 97 Official build - Added instructions to stage 36
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
During the build in stage 62, two fuel lines have to be fitted. It is a task of near impossibility due to the fact that the fitting locations are far inside the engine assembly.
The fuel lines are available before stage 36, where fitting them is simple.
Look at stage 36A to see the added instructions:https://forum.deagostini....1734868449.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=8989174
 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Cheers for that Roy. Now done 👍. I can see what you mean that it would be really hard later on Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Motor Modeller - F1
Lotus 97T
