12 Pages «<45678>»
My Senna 97T build Options
Steve279021
#101 Posted : 22 January 2025 15:41:56
Stage 43, right side timing belt and pulleys. The belt seems a little on the long side. I know it makes assembly easier but it makes the belt look really loose.
Dodge charger build complete
#102 Posted : 22 January 2025 16:23:06
I also noticed the belts were rather loose.
I contemplated cutting a small piece out and gluing with cyano but when the engine is attached to the body you can't really see them anyway.
Looking good though. Keep it coming.BigGrin
Steve279021
#103 Posted : 23 January 2025 13:23:49
Stage 44. Left side timing belt. This side fits much better then the right side. Maybe a shorter belt? I should have compared them before fitting them to see. Anyway that's pack 9 finished. I have pack 10 here to do now
Steve279021
#104 Posted : 23 January 2025 13:26:24
Pack 10
Steve279021
#105 Posted : 23 January 2025 13:50:16
Stage 45. Oil pipe connections
They grey pipe (45c) was a little long so I chopped it down a bit. Also be careful when installing pipe 45d and fitting 45e as there are fragile parts involved here. Luckily I didn't break anything🙌
Steve279021
#106 Posted : 23 January 2025 14:18:40
Stage 46, fuel and oil lines. Part 46f was quite loose so I will leave it off for now until it needs to be connected the other end as I don't want to lose it.
Steve279021
#107 Posted : 23 January 2025 14:54:51
Stage 47, gearbox rear housing
Steve279021
#108 Posted : 23 January 2025 15:17:28
Stage 48, right gearbox and differential housing
Steve279021
#109 Posted : 23 January 2025 15:56:22
Stage 49, left gearbox and differential housing.
Steve279021
#110 Posted : 24 January 2025 18:02:44
Stage 50. Engine and gearbox married up. That's pack 10 done now. Waiting for pack 11.
Steve279021
#111 Posted : 19 February 2025 10:19:05
Pack 11 here now
Steve279021
#112 Posted : 21 February 2025 13:32:10
Stage 51. Gear selector, oil cooler and rain light
#113 Posted : 21 February 2025 15:28:07
Hi Steve,
Coming on nicely, WTG Cool
(Derek) Admin
#114 Posted : 21 February 2025 16:31:40
Great stuff.
Move the oil cooler so it sits central on the supports or the oil pipes won't connect.
Steve279021
#115 Posted : 22 February 2025 02:51:18
Cheers guys. I just rechecked the instructions and it shows the cooler to be offset and the bands go over the raised sections of the cooler which is what I have done. Maybe it will become apparent when I come to putting on the pipes.
Steve279021
#116 Posted : 24 February 2025 19:04:35
Stage 52. Oil tank connections. I found when fitting the black pipe to the 2 pronged fitting in the back of the engine that it was easier to remove the fitting from the engine,fit the black pipe to the correct prong and then fit the fitting back on to the engine. There was a danger of the fitting breaking if i didn't do it this way. Also the oil cooler pipes fitted perfectly so the cooler was in the correct position.
Steve279021
#117 Posted : 28 February 2025 15:39:01
Stage 53. More oil pipe connections
Steve279021
#118 Posted : 28 February 2025 15:58:40
Stage 54. Left upper rear suspension arm and shock absorber. Where the front of the arm mounts to the gearbox there was a large build up of paint which needed to be removed before it would fit in. Not a biggy though.
Steve279021
#119 Posted : 04 March 2025 15:05:27
Stage 55. Left rear suspension continued
Steve279021
#120 Posted : 04 March 2025 15:26:17
Stage 56. Left rear hub and drive shaft. That's pack 11 finished. Waiting on pack 12 now
12 Pages «<45678>»
This page was generated in 0.539 seconds.
