Issue 14
Assembling the Base and Doghouse Roof Check which way around the base goes. Fit the doghouse roof onto the post as shown in picture 2. Use a little quick drying glue to hold it in place. The assembly will look as also shown in picture 2.
Place the first of the cloud parts (Part D) to the base, using a little quick drying glue, picture 3. Note: All the cloud pieces are labelled with letter from A to E on the back of them. Place the second cloud (Part E) in place, using a little glue as before, picture 4.
Assembling the Left and Right Box Sides Retrieve the Woodstock’s Nest scene from the previous issue and one of the side panels that came in this issue, as shown in picture 5. Place the side panel so that the tabs fit and lock into place as shown in picture 6. DO NOT glue this in place as it will be removed in a later issue. Next, place the opposite side panel in place as before, picture 7.
If you hadn’t already, glue Woodstock to the nest along with the snoopy figure that came with this issue, pictures 8 and 9.
Issue 15
Assembling the Base and Floral Display Take the three clouds and glue them in place with quick drying glue as shown in picture 2. Note: Each cloud has the letter on the reverse side.
Using some quick drying glue, take the base from issue 14 and fit the wall, picture 3. Now take the two side panels and fit them in place. Note: DO NOT glue these in place, picture 4.
Fit the back of the box by fitting the two tabs at the bottom and the two tabs over the hooks on the back of the wall, pictures 5 and 6. Now take the two side panels, noting their orientation and fit the left-hand panel as shown in picture 7. When fitting the panel, apply a little glue to the front edge of the wall. Now fit the right-hand panel in the same way, and then using the two screws provided, secure the back panel as shown in pictures 8 and 9.
Fit Snoopy (The Flying Ace) onto the top of the roof, using a little quick drying glue, picture 10.
Cut out the leaf cutouts and the flower cutouts and using PVA glue attach the flowers to the leaves as shown in pictures 11 and 12.
Take the flowerpot from issue 14 and fill it with PVA glue, arranging the made flowers in the pot. Glue the pot to the bedside stand as shown in picture 13.
Issue 16
Assembling the Background and Floral Display Take the two flower cutouts, pink and purple and paint half the pink flower cutouts yellow and half the purple flower cutouts white. Leave these to dry, picture 2. Cut out all the flower petals. I placed all my petals in order of colour.
Next, using PVA glue, attach the petals to the background, using most of the smaller petals at the back and the larger petals towards the front. This process is very time consuming but worth the effort when finished, picture 3.
Take the base, from issue 6, the one with Snoopy and his three brothers in the bed, along with the back wall as shown in pictures 4 and 5. Fit the back to the base using a little quick drying glue to the tabs at the bottom of the base to secure the back panel in place, picture 6.
Take the two side walls and place them as shown in picture 7. Note: DO NOT glue these. Now place the floral background in place, picture 8 and glue the tabs at the back of the wall as shown in picture 9.
Place the snoopy figure in the scene using quick drying glue on the tab to secure him in place, picture 10.
Issue 17
Assembling the Easter Scene Take the first house and secure it using quick drying glue in the tab at the back of the background, picture 2. Take the other house and two trees and place them next to the first house as shown in picture 3.
Next take the clear support post and attach the easter egg on the flat end of the support, picture 4. Place the other end of the support into the hole on the slope of the background, using quick drying glue, picture 5. Using quick drying glue, attach Linus to the scene as shown in picture 6.
Finally, temporarily fit the two side walls to the bed scene, picture 7.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 18
Assembling the Base and Walls Take the base and orientate it the way as shown in picture 2 with the yellow/green side towards you. Find the back wall and check which way around it goes, picture 3. Fit the cloud part into the 4 holes on the back wall, then turn the assembly over and apply some quick drying glue to the tabs to hold it all in place, pictures 4 and 5. Place the back wall assembly to the base as shown in picture 6, gluing the tabs at the bottom.
Take the two side walls, picture 7, and place them as shown in picture 8. Note: DO NOT glue the side panels.
Picture 8 shows the complete assembly.
Adding the Grass and Flowers to the Easter Scene Cut out the grass cutouts. You will need about four of each of the two types of grass to complete the scene. When cutting them out, break off some of the blades and turn some around so when gluing then to the scene, they don’t all look the same, picture 9.
Glue the blades of grass at the bottom of the base using PVA glue and add some of the flowers.
Picture 10 show the completed scene with grass and flowers.
