Snoopy's House Official Build Pack 6 Options
#1 Posted : 20 March 2025 10:31:06
Issue 19
Assembling the Mountains and Rock Scene
Take the Beagle Scouts scene from the previous issue and place the mountain in position by pressing the two tabs securely. You may want to use a little quick drying glue to hold it in place, picture 2.
Now fit the rocks in place to both sides as shown in picture 3. Again, use glue to secure them in position.
Take the snoopy figure from the previous issue and place him as shown in picture 4.
Take the three Beagle Scout figures and the mounting posts and glue one end into the figure. Do this with all three, picture 5.
Place each one in one of the three holes as shown in picture 6.
Arrange them in the positions as shown in picture 7.
#2 Posted : 23 March 2025 18:02:05
Issue 20
Take the base and the stand from this issue, note their orientations as shown in pictures 2 and 3. Using some quick drying glue, place the stand on the base, picture 4.
Now place the window and wall part into the base using quick drying glue, picture 5.
Take the flock powder that came in issue 11 and using PVA glue, sprinkle the flock on the grass base as shown in picture 6. Once dry, glue it in place on the base and wall, picture 7.
Place Patty on the stand, but DO NOT glue in place just yet, picture 8.
Now take the ‘Snoopy’s Three Brothers’ scene and glue the back wall in place using quick drying glue. Once dry, place the two side panels in place, DO NOT glue these, picture 9 and 10.
Place the Snoopy bed in position, picture 11, again, DO NOT glue, as more will be added later.
#3 Posted : 23 March 2025 18:19:16
Issue 21
Glue the flowers in the window box, using quick drying glue, picture 2. Glue the window box into the slot under the window as shown in picture 3. Take the back wall part and stick the background sticker in place as shown in pictures 4 and 5.
Glue the back wall in place, picture 6 and add the two side walls, picture 7. Note: DO NOT glue the side walls in place.
Now add the Snoopy to the scene by gluing him in place as shown in picture 8. Picture 9shows the scene completed so far.
Retrieve the Snoopy Bed scene and place the two box sides in position. Apply a little quick drying glue to the side tab ends, then place each box side, aligning the holes as shown in picture 10.
Finally, take the two screws provided and secure them in place as you have done before in previous assemblies, picture 11.
Picture 12 shows the complete assembly for this issue.
#4 Posted : 25 March 2025 21:26:57
Issue 22
When assembling the seashore scene, use quick drying glue to attach the sea piece to the beach part, picture 2. Don’t worry about any gaps around the edges at this point.
Before we add the sand, cut a cocktail stick into three pieces and place each one into the holes as shown in picture 3. This will stop any glue and sand from filling these holes.
Using some PVA glue, paste the beach with the glue before sprinkling the sand over it. Whilst you have the glue available, paint glue around the edges, filling the gaps and maybe paint some on the water to give larger waves. Picture 4 shows the assembly glued and sanded. Before allowing to dry, take out the cocktail sticks before they set in place and difficult to remove, picture 5. Position the deckchair into two of the holes. Place Woodstock in the deckchair using a tiny bit of quick drying glue. Picture 6 shows them in place.
Allow this to dry thoroughly, preferably over night so the glue around the edges and on the water have turned transparent.
Now it is time to paint the waves with a white acrylic paint. I also used a little white paint to highlight the sand, using the dry brush method, picture 7.
In the next issue we complete the scene. That complete the assembly for this issue.
#5 Posted : 31 March 2025 22:36:25
Issue 23 Part 1
Place the two clouds (A & B) to the back wall and secure both with some quick drying glue, picture 2. Now take the base from issue 22 and place the back wall into the base slots and secure with quick drying glue as shown in pictures 3 and 4. Note the orientation of the base. The lugs should be at the back, picture 3.
Glue the umbrella pole into the umbrella as shown in picture 5.
Place the beach scene base into the back wall by inserting the two pins into the corresponding slots. Secure with glue, picture 6. Now fit one of the side panels in place, also picture 6, but do not glue this in place. Fit the other side panel in the same way. Take the umbrella and glue this in place into the hole next to the deckchair, picture 7.
Take Snoopy and the support pole and glue this in place as shown in picture 8. Take the assembly and glue the other end of the support pole into the hole in the back wall, picture 9.
That complete part 1 of this issue.
#6 Posted : 06 April 2025 22:23:13
Issue 23 Part 2
Making Water Drops
Start by taking the templates and cut through the lines on the long strip. Fold the strip to make a frame. Lay the bottom on the template and fix to the frame with sticky tape, picture 1.
Cut the nylon line into six parts approximately 10cm long (4in). Lay them out placing each end of the line into the cut slots at either end of the frame. Repeat with the other five nylon lines.
Place a blob of PVA glue on a cocktail stick and apply a drop to the line immediately above the first of the dots on the base template. Continue to place a blob of glue on all the nylon lines to correspond with the template, pictures 2 and 3.
Allow this to dry overnight, picture 4. When the glue droplets have set, paint each blob with a blue acrylic paint, picture 5.
Cut the nylon lines about 3mm at the end of where the blobs are the closest and between 3 and 7mm at the other end.
Using glue, place each of the lines into one of the 5 holes at the end of the watering can. Make sure the end, where the blobs are the closest, are at the watering can end, picture 6.
I used some quick drying glue to hold each line in place. Once they were all positioned and the glue had dried, I added a blob of PVA glue around the top of the watering can as an added precaution to stop them from falling out. You can also see this in picture 6.
Apply some glue to Patty’s foot and press in place into the hole on the stand and fan out the water drops over Snoopy.
This page was generated in 0.265 seconds.
