Joined: 05/04/2016 Posts: 720 Points: 2,163 Location: Ferrara
A friend drove me crazy a few months ago with a screenshot of the collection launched only for the UK market.....after a while DeA decided to launch it worldwide and I am infinitely grateful to them. I think it was the model I wanted the most: the RB19 with which Max graduated for the 3rd time world champion in Qatar in the sprint race. (actually at the top of all is the RB16B with which Max won his first world championship). I subscribed twice, that is, I made 2 subscriptions: I'll assemble one step by step with some slight improvements (if there are any to be done), I'll store the other to make it in the GP Qatar 2023 version (even if it will be very complicated for the sidepods, letter box air intakes and bottom entry) I'll assemble this one as I go and then place it in the living room or bedroom (with the kind permission of my girlfriend) For once I'll start with some references using Max's 2023 book. The quality seems very good, good couplings and good carbon weave, no visible screws (especially on the vertical profiles of the wing). The only flaw is the usual bad coupling between the two nose shells. As for possible extra detail: perhaps the color of the supports between the various wing profiles, the reinforcement patches of the supports themselves and little else. This assembly will help me understand the defects, to understand how and where to modify the second one. The most complicated part will be his livery which is as beautiful as it is difficult. After assembling the first 2 issues, I then put everything in my "sanctuary" of Max for his 4 world championships.              Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Well it`s good to see a members build on this one.
You have my attention for sure.
Regards delboy271155 (Derek)COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote: Well it`s good to see a members build on this one.
Regards delboy271155 (Derek) Thanks Derek, i'll do my best with this beast! Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
If it is going to be anything like you did with the Porsche, you also have my attention too. Great to see you on this build and I’m definitely looking forward to seeing what you do with this.
MarkRegards Markwarren (Mark) Admin
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,770 Points: 17,462 Location: ipswich
It's great to see another build of this beast. I'll be looking in at each update.
Second shipment arrived home. There are 3 files that include the first hub-wheel-front left wheel arms group. I start with the assembly of the wheel group only (file 3) ... quite simple and elementary. But the defects and the shortcomings are quite accentuated. This element is so visible and characteristic that left like this it is not correct and very bare.     And now let's start with the "shopping list of defects/shortcomings" - oversized tire shoulder ribs - incorrectly shaped lenticular funnel - lenticular color too opaque - lenticular support ring details too evident - no tire valve - no barcode labels on tire shoulder - no writing on tire shoulders - no balancing weight on external lip - no Dutch flag sticker on external lip - no wear holes on tire footprint as desired: no tread wear and rim bead too new, in many photos and races it is marked. Redoing the lenticular and the valve is not a problem, now I have to decide (but I think without even thinking too much) to redo the tire as well. I will wait for the decal until the end because I think there will be a lot of integration to do.                  Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Yesterday I started to work on fusion and did a first test with 0.133 mm ribs....from the desktop they always appear huge, but when holding the piece in your hand they are almost invisible. I printed only 1/4 of the tire to also have feedback on the mounting tolerance on the rim, I also added wear control holes to the tire. I modified by bringing the ribs to 0.2 mm Now I am always reprinting a quarter. If the visual feedback is ok, I will proceed to print the entire tire. I also noticed that the profile of the kit tire footprint has too much of a slope towards the shoulder.        Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
I've printed the second beta test. The phone camera can't handle grays, so I used the marker to highlight the lines I compared the 0.2 mm with 0.133 mm and compared them with the enormous ones from the kit. The 0.2 mm seem right to me, hoping that the primer and color don't drown these ribs too much A few more finishing touches and then I'll move on to printing the entire tire (which I'll have to tilt): the x and y planes of the print bed of my Mars don't contain this rubber beast that measures 88 mm    Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Looking good. Regards Markwarren (Mark) Admin
Stage 4 First part of the front left wheel suspension hub group. The twill weave of the carbon dominates. Two round pieces and a PE strip.....more than PE a real metal ribbon engraved with micro ventilation holes and a metal toroid: they simulate the carbon disc. The arms in their shape are correct, chromatically they are not right. The rear cover of the hub (which in reality is a single piece with the air deflector with the Hard Rock sponsor) is always all in twill weave...when in reality it is a puzzle of chequered carbon with various reinforcement strips of finer weaves.        Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Stage 5 Here the components to continue assembling the suspension group, steering, left front hub. Always twill weave and incorrect colors; but the first mini macro details that catch the eye are starting The deflector or fin above the wheel has various functions, and one concerns aerodynamic flows. It has an open gill in the upper curved part and 2 open gills in the lower area that serve to channel the air where Newey wants it. In the kit everything is closed. The arm that adjusts the camber angle has a cover that reveals the adjustable tie rod. Here the arm is flat and smooth Then the small air intake on the brakes needs to be reviewed. Carbons and colors to be redone. I'm then waiting to see the final part of the hub hoping that they made the correct nose cone with the 3 fins... otherwise I'll get back to work with the 3d.        Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
From the various photos you can see that the suspension arms and the various tie rods are all built with a very fine composite. Depending on the light they appear black, in others a dark gray brown, in others an almost gunmetal gray.... the usual trap of the textures like on the McLaren mp4/4. As already said, the camber adjustment cover is missing and the attachments to the frame need to be reviewed in their color. The carbon of the rear hub deflector is a chequered with various patches, here and there and with various insertions of other fibers especially in the cutting area. I'm not going to look at the hub and the disc, I'll cover everything with the basket when it arrives In the meantime that my Mars produces the first tire (I've reached V.04) I started working on the deflector by opening the gills. Depending on the race (like Monaco) they added flaps in the lower part of the deflector perhaps to better channel the flows towards the flat bottom. For now I'll open them, then I'll see which race to christen (which will necessarily be the first part of the season before they changed the side pods and radiator air intakes).             Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
I printed rubber, and to limit the sprue pins as much as possible, I printed it standing up instead of lying on the shoulder. I wet sanded it with 800 to even out where the layers were visible and as far as I could without erasing the ribs. I then moved on to the primer and two coats of gloss black. 6 hours of drying and then I started studying how to make a minimal wear effect from a single running-in lap look realistic as is done for the installation lap or when they leave the pits for the last time to then go to the grid before the start of the GP. I passed a 3m microfine sponge to opaque it, then I used the black rubber tamiya brushing it in a wild boar fashion back and forth. This has (imagined and also unexpectedly) produced what happens with paints (especially Tamiya), the brush carries the first layer and creates accumulations and veins that would make you swear, here instead they are just right for me generating a pick up effect like marbles left on the track or in pit lane. The opacity and roughness were already good, I evened it out with a general pass of wheatering "soot" only on the footprint on the ground. The effect seems plausible and acceptable to me For the decals I'll wait (even if I already know that they will be soft and therefore red stripe) when I will do the total cart of everything that will be added. After a week between studying photos, profiles, importing profiles, my tire is a little better than the kit tire.           Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Very nice work. Mark Regards Markwarren (Mark) Admin
Numbers 6, 7, and 8 arrived a while ago. The first lower part of the survival cell has arrived. Here too, the carbon fiber ribbon twill...but the texture doesn't even remotely resemble the real thing, whereas on the MAX single-seater, it's a much thicker, chequered-like texture. I'm almost certain the FIA logo is missing, but I'm waiting for the upper part. Anyway, we'll do it again today; we'll assemble it tomorrow.       Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Next issue: more details of the braking system, carbon duct, and caliper (as my friend calls it: made by the Romulans). The various pins or "pimples" are designed to dissipate heat since the entire hub assembly is completely enclosed from the 22nd (including the lenticular disc on the rim), so temperatures are a little higher. Compared to reality, which is a headache to replicate unless you get the entire exploded view directly from Milton Keynes, the model is at the bare minimum. I always wait for the final basket to hide everything, and that's it... assuming they even do it, otherwise I'll have to rely on my printer.       Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Last shipment: the upper and lateral protection around the helmet and shoulders. A sort of foam "collar" that is put on once Max is in the cockpit, then removed and pressed down. I was hoping not to even look at the part here, but alas, there are some differences, which I had to keep. The 1:1 has some bumps that are likely to be helmet stops when taking fast corners with more lateral G. I think they provide additional lateral support to avoid excessive strain on the neck. Under the mini headrest cushion, there is a recess...completely missing. The Mobil One decals on the side are larger than they should be. In short...a lot of stuff.      Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
