1:6 Shelby Mustang part 85A Options
#1 Posted : 27 May 2025 12:03:52
Hi 1:6 Shelby builders, BigGrin
Just a general notice for those building this kit.
In issue 85 step 1, the instructions indicate a pin on part 85A. This is incorrect so please don`t panic and start ordering replacement parts. There is and should be a small hole where the pin is indicated.
The "notch" in part 85B should be positioned over the hole in part 85A, then in issue 86, the shroud 86A has a pin that fits into both parts 85A + 85B.
Hope this helps.
This page was generated in 0.278 seconds.
