Snoopy's House Official Build Pack 9 Options
#1 Posted : 02 June 2025 20:12:38
Issue 34 Part 1
Making the Chairs, Cereal Bowls and Box Top LEDs
Separate the two sets of four legs on the first sprue for the larger chair parts, pictures 2 and 3. Using a small drop of quick drying glue, place the legs onto the four slots on the underside of each chair, picture 4. Now do the same with the parts for the smaller chair, pictures 5, 6 and 7.
Take the backrests and place them into the slot at the back of each chair seat using a drop instant glue, picture 8.
Next, take the bowls and glue the cereal inside the bowls as shown in pictures 9 and 10.
That completes part 1 of this issue.
#2 Posted : 02 June 2025 20:15:11
Issue 34 Part 2
Place the three assembled chairs into the holes in the box as illustrated in picture 11. Use double sided tape or quick drying glue to attach the Sally and Snoopy figures to the chairs as shown in picture 12. Place the milk carton you made in issue 32 and glue it to Sally’s hand, picture 13. Picture 14 shows the scene with the table in place.
Take the top of the figurine box “Joe Cool” you partly assembled in issue 32 and fit the short and long LED strips as shown in picture 15. Test the lights at this stage, picture 16, before placing the inner liner over them, picture 17. Now attach the top to the box, making sure the wires go down the back of the rear wall and glue in place, picture 18.
Picture 19 shows the finished assembly for this issue.
#3 Posted : 03 June 2025 10:40:13
Issue 35
Making the Kitchen Unit and Blender
Check the orientation of the back part of the kitchen unit. The top has a hole where the LED bulb will sit. Attach the bottom cupboard unit to the back base using quick drying glue, picture 2. Place the top cupboard in the same way as shown in picture 3.
Place the jug into the slot on the blender body, as this will only fit one way, picture 4. Next, glue the lid onto the jug part of the blender. Place a piece of double-sided tape to the underside of the blender and place it on the shelf of the kitchen unit as shown in picture 5.
Finally, glue the Charlie Brown figure to the chair, picture 6.
#4 Posted : 05 June 2025 10:29:29
Issue 36
Making the Kitchen Stool and Towel
Take the stool parts and cut the legs from the sprue, picture 2. Attach the legs to the stretcher using quick drying glue, pictures 3 and 4. Now fit the seat to the top of the legs as shown in pictures 5 and 6.
Fold the towel in a similar to the one shown in picture 7, using double sided tape to hold it together. Apply a piece of double-sided tape over the stool as illustrated in picture 8. Place the towel over the tape so it hangs to one side, picture 9.
Picture 10 shows the stool in place in the scene.
Take the top box part and place the short and long LEDs as shown in picture 11.
Attach the circuit board as you have done previously, securing it with two screws, picture 12.
Finally, test the lights using the tester as before, picture 13.
#5 Posted : 07 June 2025 18:36:21
Issue 37
Assembling the Dresser/Sideboard
Attach the top of the dresser to the dresser body using quick drying glue, picture 2. Take the two jars and fit one of each base inside the jar, picture 3. Attach the lids to the jars using quick drying glue, picture 4.
Glue the bunch of bananas to the fruits and then insert the fruits in the fruit bowl using quick drying glue, pictures 5, 6 and 7.
Now place the plates and jugs to the dresser using either double sided tape or quick drying glue as illustrated in picture 8.
Place the two jars on the worktop next to the blender, picture 9.
The final picture shows the fruit bowl, breakfast cereal and the bowls of salad painted to give them more depth and colour.
#6 Posted : 08 June 2025 18:45:05
Issue 38
Assembling the Box Top and Setting the Table
Set the table with the salad bowls, spoons, the cereal bowls, teapot and salt and pepper set as illustrated in picture 2. Picture 3 shows the table in the scene.
Take the box top and attach the circuit board into the box using two of the screws as you have done in previous issues, picture 4. Place the LED strips in as shown in picture 5.
Fit the cover over the LED strips and attach the LED strip connectors and the bulb to the circuit board as shown in picture 6.
Picture 7 shows the LED being tested.
#7 Posted : 10 June 2025 19:34:01
Premium Pack 1
Special Figurine Box Collection (Snoopy the Astronaut)
In the same way as the regular figurine boxes, fix the back wall into the slots on the base using some quick drying glue, picture 2. Fit the lunar surface to the base pushing it onto the mounting posts, picture 3. Now fit the two side panels into the slots, but do not glue these in place, picture 4. Place the box back behind the back wall positioning the tabs, picture 5.
Apply a little quick drying glue to the front end of the side panels and then fit the red side panels in place as shown in picture 6. Next, using two screws, secure the back panel to the base, picture 7.
Take the Snoopy figure and the support post and glue it in place as shown in picture 8. Secure the other end of the post to the back wall, picture 9.
Place the two LED strips into the box top as illustrated in picture 10. Place the circuit board in place using two screws, picture 11. Place the box top liner over the cables as you’ve done in other assemblies, picture 12, along with testing the lighting circuit.
Glue the box top to the rest of the box assembly, picture 13.
Picture 14 shows the first Premium Figurine complete.
This page was generated in 0.277 seconds.
