12 Pages «<678910>»
My Senna 97T build Options
Steve279021
#141 Posted : 06 June 2025 15:56:37
Stage 64. Gear linkage and right side fairing bracket
Dodge charger build complete
Steve279021
#142 Posted : 06 June 2025 16:18:23
Stage 65. Left and right waste gate pipes. There was 2 radiator pipes included in this stage but are not fitted yet.
#143 Posted : 06 June 2025 17:00:08
Hi Steve, BigGrin
Good to see you back on this one, its looking good. WTG.
Steve279021
#144 Posted : 06 June 2025 17:01:31
Cheers Derek, seems like ages since I was last on this
Steve279021
#145 Posted : 09 June 2025 13:23:52
Stage 66, left turbo and exhaust
Steve279021
#146 Posted : 09 June 2025 13:42:53
Stage 67, left turbo and oil pipes
Steve279021
#147 Posted : 09 June 2025 14:40:58
Stage 68. Left turbo inlet. That's pack 13 done now and on to pack 14👍
#148 Posted : 09 June 2025 16:27:44
WTG Steve, looking good.
ThumpUp ThumpUp ThumpUp
Steve279021
#149 Posted : 11 June 2025 11:41:49
Cheers Derek👍.
Pack 14
Steve279021
#150 Posted : 11 June 2025 11:53:15
Stage 69. Left intercooler and chassis cable connectors, 1 connector on each side of the chassis.
Steve279021
#151 Posted : 11 June 2025 12:06:38
Stage 70. Left intercooler fitted
Steve279021
#152 Posted : 11 June 2025 12:23:47
Stage 71. Left intercooler air duct and name plate fitted
#153 Posted : 11 June 2025 12:46:30
Hello Steve.
The air duct doesn't look quite correctly fitted.
There shouldn't be any of the grille part of the chrome area showing. The parts should be tight together.
Probably just a bit of loosening screws and wiggling.
Steve279021
#154 Posted : 11 June 2025 12:56:40
I'll have a look later. I can't see how it would be adjustable though, both the intercooler and duct screw into fixed holes in the floor but I will investigate further
Steve279021
#155 Posted : 11 June 2025 14:18:46
I have had it all off and tried to adjust and there is no adjustment at all, this is how the 2 parts want to sit. Not sure why this is, I can only wait till I get the other side done and then compare it.
It looks as though my intercooler is a bit larger then yours maybe. Possibly the production of the parts has changed. I don't know🤷‍♂️
Edited:
I have just watched the deagostini YouTube video on this stage and done a screen shot. Seems to be the same as mine
Steve279021
#156 Posted : 12 June 2025 11:44:30
Stage 72. Engine ecu
Steve279021
#157 Posted : 12 June 2025 12:04:12
Stage 73. Left side pod continued and intake grill. Them 2 screws at the bottom of the grill are very tricky😲
Steve279021
#158 Posted : 12 June 2025 12:21:10
Stage 74. Left radiator. A nice easy stage to finish off pack 14. Waiting for pack 15 now.
#159 Posted : 12 June 2025 20:26:52
Looking good Steve. Nice to see you cracking on with this again.BigGrin BigGrin
Steve279021
#160 Posted : 12 June 2025 20:35:22
Cheers Mark👍
12 Pages «<678910>»
This page was generated in 0.356 seconds.
