Issue 93
Fitting the Indicator Lights Remove the two indicator lights from the sprue. Push both the lights into the left and right rear window supports, picture 2.
Issue 94
Fitting the Widow Frames First, take the sheet of double-sided tape that came with this issue and place the tape onto both the rear window frame (94A) and the rear window front frame (94B), pictures 2 and 3. This will help to hold the frames in place on the window.
Picture 4 shows both the frames in place.
Take the supports you assembled in the previous issue and place them in the corner where the front and rear frames meet, pushing the three pins into the corresponding holes in the frames, picture 5.
Slot the rear window into place on the rear body panel and secure it in place using 4 x SM screws, picture 6.
Picture 7 shows the complete assembly for this issue.
Issue 95
Fitting the Rocket Launchers (Not exhausts pipes as described in the magazine) Begin with the longest rocket launcher (95B) and push it onto the middle of the rocket stack (95A). Then fit the two smaller rocket launchers (95C) in the same way, picture 2.
Push the rocket launcher assembly through the holes in the rear body and secure it in place using 2 x AM screws, picture 3.
Picture 4 shows the assembly in place on the rear body.
The final picture is from a scene in the show, showing the rocket launcher in operation.
Issue 96
Fitting the Trunk (Boot, for us English people) Use 2 x AM screws to fit each of the left (96B) and right (96C) hinges to the trunk lid (96A), picture 2.
Next, fix the trunk prop catch (96D) to the trunk lid, picture 3.
Secure the trunk assembly to the rear body panel as shown in picture 4, using the two brackets (96E) securing them in place with 4 x CM screws.
Picture 5 shows the assembly complete for this issue.
Issue 97
Fitting the Hinges to the Door Secure the upper hinge (97B) to the inside of the left door (97A) using an EM screw. Do the same with the lower hinge (97C), picture 2.
Picture 3 shows the assembly complete for this issue.
Issue 98
Installing the side Piece Secure the inner side piece (98A) using 3 x CM screws as shown in picture 2.
Finally attach the left door handle (98B), picture 3.
Issue 99
Fitting the Hinge Panel Secure the left hinge panel (99A) on the rear of the door so it covers part of the door hinges. Secure it in place using 2 x CM screws, picture 2.
