Part 13 Options
redpiperbob
#1 Posted : 13 August 2025 12:08:28
Rank: Newbie
Careful all the Exhaust numbers are all wrong If you look at the tubes two of them have holes in both ends these are 13b and 13c they look nothing like the pictures.
13f and 13g have the slight bends and 13d and 13e have the tight bends.
I hope this helps
Bob
Please note the response from Roy who is building the official build in post 4.
Admin
redpiperbob
#2 Posted : 13 August 2025 12:18:30
Rank: Newbie
By the they are left and right handed. There are small flats on the endsthat plug in to 13A dont thighten the screw in step 13-1until you have completed step 13-6
Hope this helps
Bob
#3 Posted : 13 August 2025 14:16:56
I'm about to start on that stage so I'll have a careful look.
Thanks for the heads up.
Roy.
#4 Posted : 16 August 2025 17:39:14
I've just completed this stage.
All the part numbers and shapes/positions are correct.
The printed instructions are also correct.
The back plate also has the location numbers on the reverse and following this, assembly is very easy.
Roy.
This page was generated in 0.031 seconds.
