Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,359 Points: 22,384 Location: Northamptonshire, England
Issue 49
Assembling the Christmas Scene Fit Charlie Brown figure in as shown in picture 2, followed by the Sally figure, picture 3. Fit the wall in place as illustrated in picture 4.
In this next part I removed the Christmas tree and added some more decorations, picture 5. Picture 6 shows it fitted in place.
Take the box top from issue 48 and add the LED strip as shown in picture 7. Make sure the socket on the circuit board is on the right-hand side.
Fit the top liner and the cable into the connector, picture 8.
Place the two side panels as you have done previously in other issues and secure them in place using the two screws provided, picture 9.
Issue 50
Assembling the Christmas Scene Continuing the winter scene from the previous issue by attaching the two presents in the two slots in front of the Christmas tree, picture 2.
Using double sided tape or a spot of glue place the cookies to the plate that Snoopy figure is holding, picture 3.
Glue Snoopy in place as shown in picture 4.
Add the circuit board to the box top as shown in picture 5, using the two screws provided.
Issue 51
Assembling the Snowbank and Frozen Lake Scene Retrieve the Surfing Snoopy scene from issue 23, picture 2. Take the back wall and place it on the opposite side of the Surfing Snoopy scene as shown in picture 3.
Glue the snowbank to the back wall and the two pins on the base as illustrated in picture 4.
Temporarily fit the tree, frozen lake and Snoopy to the scene, but DO NOT GLUE these in place just yet, picture 5.
Issue 52
Assembling the Snowbank and Frozen Lake Scene Take the three trees and bend the wire, cutting some to make different size branches, picture 1.
Fit the trees as illustrated in picture 2, along with the forest part.
Finally, fit the two side panels and add Sally to the scene, picture 3. Do Not Glue these in place just yet.
Issue 53
Assembling the Snowbank and Frozen Lake Scene Add the bench to the scene as shown in picture 2.
As you have done many times before, attach the red side panels to both scenes, screwing it to the base using the two screws provided, picture 3.
Assembling the Box Top Fit the circuit board to the box top using the two screws provided, picture 4.
