Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
 Might be awhile till the next update, as its the main body shell, will be back with more asap. Thank you fro looking in. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
I’ve come to a bit of a standstill at the moment, as I’m needing some more issues. But I’m not going to pay the stupid money people are asking for, so this project is on hold. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Well they say a lot can happen in 24hrs…. I’ve managed to get all the issues I need except one, just need issue 107 So at least I can carry on it I get to that issue. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So just some little redos. Needed to remove the B upright from the door.   I did paint them but I didn't like the finish as per the bottom version, so I use bare metal foil as per the top one.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Worked on the inside of the front doors...    There not finished yet as I need to fill the two holes at the bottom once there screwed to the outer panels, this area will be orange as so will the white strip. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,769 Points: 17,459 Location: ipswich
Looking really impressive. Keep it coming.
Thank you Roy So I've started work on the front end. Got to convert this complete area..   First this lip needed to go   But then I needed to move the centre part backwards as it to far forwards   To do this I just moved it so it was behind the metal bottom part  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Next was to work out the bumper So I took the chrome section  And cut that up  Used the bottom part as my starting point  Added the top section so the bumper looked full  Used the side parts to make the end sections      My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So onto the centre area with the grill and lights.   Because of the way the manufacture designed the section behind there was much I could do about where I put parts. Just a little playing around  I was trying to keep this old school by build the parts from what I had, so I looked at thin metal to make the centre area  But I didn't like the look so I designed a stl file and printed one  It is a lot better and so I do these in resin as these where just trial  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Really looking good. It's going to be a stunner.
Thank you Roy That means a lot to me coming from the car master. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So heres some more..  My resin vent, toke me long to design them than it did to print them   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
The interior    and the boot  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
For some reason the paint has ended up with two different colour shades, I checked the batch numbers and gave the same amount of primer and top coats and lacquer but there is a slight difference in some panels. I'm just going to go with it I don't want to stipe it all down and redo it all so for me the car has had some rework done to it those good old boys have been a bit reckless   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Engine done   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
    There is a flag, but I'm just waiting for admin to say yes or no to putting a photo up, just in case the forum doesn't allow it. So just the front area to finish which should be tomorrow except for the bull bar and she will be complete, I was going to look at making the bar but found one online so I'll wait and see what its like. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So not bad for a secondhand kit from you know where that was damaged, now all I need to do is get rid of all the other issues I don't need  oh and find somewhere to display her My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Wow. That looks amazing. I bet you're chuffed with it.
Hi Roy, I'am she does really look the part. So with permission from Admin here is my modified version of the Dodge Charger.        My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
