2 Pages <12
1969 Dodge Charger Options
Mustang
#21 Posted : 01 September 2025 23:13:44
To build:-
Mustang
#22 Posted : 01 September 2025 23:15:40
Might be awhile till the next update, as its the main body shell, will be back with more asap.
Thank you fro looking in.
To build:-
Mustang
#23 Posted : 13 September 2025 20:51:52
I’ve come to a bit of a standstill at the moment, as I’m needing some more issues.
But I’m not going to pay the stupid money people are asking for, so this project is on hold.
To build:-
Mustang
#24 Posted : 14 September 2025 22:28:34
Well they say a lot can happen in 24hrs….
I’ve managed to get all the issues I need except one, just need issue 107
So at least I can carry on it I get to that issue.
To build:-
Mustang
#25 Posted : 15 September 2025 23:06:14
So just some little redos.
Needed to remove the B upright from the door.
I did paint them but I didn't like the finish as per the bottom version, so I use bare metal foil as per the top one.
To build:-
Mustang
#26 Posted : 15 September 2025 23:09:11
Worked on the inside of the front doors...
There not finished yet as I need to fill the two holes at the bottom once there screwed to the outer panels, this area will be orange as so will the white strip.
To build:-
#27 Posted : 16 September 2025 10:21:13
Looking really impressive.
Keep it coming.BigGrin
Mustang
#28 Posted : 27 September 2025 09:10:43
Thank you Roy
So I've started work on the front end.
Got to convert this complete area..
First this lip needed to go
But then I needed to move the centre part backwards as it to far forwards
To do this I just moved it so it was behind the metal bottom part
To build:-
Mustang
#29 Posted : 27 September 2025 09:25:18
Next was to work out the bumper Confused
So I took the chrome section
And cut that up
Used the bottom part as my starting point
Added the top section so the bumper looked full
Used the side parts to make the end sections
To build:-
Mustang
#30 Posted : 27 September 2025 09:32:59
So onto the centre area with the grill and lights.
Because of the way the manufacture designed the section behind there was much I could do about where I put parts.
Just a little playing around
I was trying to keep this old school by build the parts from what I had, so I looked at thin metal to make the centre area
But I didn't like the look so I designed a stl file and printed one
It is a lot better and so I do these in resin as these where just trial
To build:-
#31 Posted : 27 September 2025 11:22:51
Really looking good.
It's going to be a stunner.Love
Mustang
#32 Posted : 28 September 2025 23:40:09
Thank you Roy
That means a lot to me coming from the car master.BigGrin
To build:-
Mustang
#33 Posted : 28 September 2025 23:42:27
So heres some more..
My resin vent, toke me long to design them than it did to print them LOL LOL
To build:-
Mustang
#34 Posted : 28 September 2025 23:44:54
The interior
and the boot LOL
To build:-
Mustang
#35 Posted : 28 September 2025 23:48:55
For some reason the paint has ended up with two different colour shades, I checked the batch numbers and gave the same amount of primer and top coats and lacquer but there is a slight difference in some panels. I'm just going to go with it I don't want to stipe it all down and redo it all so for me the car has had some rework done to it those good old boys have been a bit reckless Blushing
To build:-
Mustang
#36 Posted : 28 September 2025 23:50:05
Engine done
To build:-
Mustang
#37 Posted : 28 September 2025 23:55:27
There is a flag, but I'm just waiting for admin to say yes or no to putting a photo up, just in case the forum doesn't allow it.Huh
So just the front area to finish which should be tomorrow except for the bull bar and she will be complete, I was going to look at making the bar but found one online so I'll wait and see what its like.
To build:-
Mustang
#38 Posted : 28 September 2025 23:57:28
So not bad for a secondhand kit from you know where that was damaged, now all I need to do is get rid of all the other issues I don't need Cursing Cursing oh and find somewhere to display her Crying Crying
To build:-
#39 Posted : 29 September 2025 10:05:06
Wow.
That looks amazing. I bet you're chuffed with it.
Love Love Love
Mustang
#40 Posted : 02 October 2025 04:08:08
Hi Roy, I'am she does really look the part.
So with permission from Admin here is my modified version of the Dodge Charger.
To build:-
2 Pages <12
This page was generated in 0.276 seconds.
