World of Warcraft Lich King Pack 4 Options
#1 Posted : 12 October 2025 20:12:02
Issue 9
The Strap of the Left Shoe
Retrieve the left shoe heel, picture 2, and place the strap (9D) into the back. Place the mounting plate (9C) over the two holes and secure in place using 2 x EP screws, pictures 3 and 4.
Place the skull ornaments (9A) on each side of the strap and secure in place using 2 x GP screws, pictures 5, 6 and 7.
Retrieve the shoe assembly from issue 8 and place the strap assembly over the shoe as shown in picture 8. To secure the strap in place over the shoe, take the central attachment loop (9G) inside the central tab of the strap, picture 9. Press the loop firmly into the two holes on the top centre of the show, picture 10.
Take the two other side taps and place the side loops into the straps as you did with the central tab. Push fit the loops in place on each side of the shoe as shown in pictures 11 and 12.
Picture 13 shows the back of the shoe.
#2 Posted : 14 October 2025 10:36:22
Issue 10
The Left Ankle
Place one of the spacers (10D) into both halves of the left ankle (10A & B), pictures 2 and 3. Picture 4 shows them in place.
Retrieve the completed ankle joint from issue 8 and place its smooth circular end between the two discs of the left ankle (10C), picture 5. Secure the two parts using the hexagonal screw, two washers and the nut as shown in pictures 6 and 7.
Finally, cover the assembly with the two halves of the ankle covers. Note the part 10C has a pin at the end, this goes into the half with the slot, picture 8.
#3 Posted : 15 October 2025 10:04:42
Issue 11
The Left Calf
Retrieve the ankle assembly from the last issue. Place this in the narrowest part of the left calf (11A) and secure it in place using a GM screw at the back of the ankle assembly and 2 x EM screws at the front, picture 2.
Note: The magazine shows the ankle assembly attached in the calf in the upside-down position. This is incorrect and will not assemble in that position. Turn the assembly over and secure it in the position as illustrated in picture 2.
#4 Posted : 16 October 2025 10:36:56
Issue 12
The Left Leg & Knee
Insert the locking piston (12C) into the joint housing (12A). Insert the spring (12A), pictures 2,3 and 4. Close the housing with the cover (12E) and secure it using 2 x HM screws, pictures 5 and 6.
Position the gear (12B) on the joint, picture 7 and align the hole and insert the pin in the two parts, picture 8.
Place the joint assembly into the assembly from the previous issue, securing it in place using 3 x EM screws, picture 9.
Assemble the joint covers (12G and 12H) and secure them together using a JP screw, pictures 10, 11 and 12.
Place the cover over the joint in the housing and secure using 2 x JM screws to the front and a KM screw at the back, picture 13.
Picture 14 shows the complete assembly for this issue.
#5 Posted : 17 October 2025 14:16:51
Issue 13
The Front of the Left Leg
Place the front of the left leg (13A) onto the assembly from the previous issue, picture 2.
Secure it in place using 6 x KP screws, picture 3.
Picture 4 shows the complete assembly for this issue.
#6 Posted : 19 October 2025 15:39:43
Issue 14
The Left Hip Joint
Before we start with this issue, the parts differ slightly from the magazine. I am waiting a reply from the production team as to whether this is correct.
In the meantime, I have gone ahead with the assembly.
Slide the joint spring (14B) onto the rod (14C), picture 2. Place the assembly inside the gearbox (14A) with the rod engaged in the notches as shown in picture 3. Place the cover plate (14D) into place as illustrated in picture 4.
Insert the outer thigh joint (14E) into the box on the opposite side of the previous assembly, picture 5. Place the inner thigh joint (14F) by inserting it inside 14E, picture 6, then secure it in place using a GM screw, picture 7, making sure it is central to the locking rod.
This page was generated in 0.296 seconds.
