Stage 103 problem Options
Steve279021
#1 Posted : 17 October 2025 12:28:36
I went to build stage 103, the right rear wheel, and found that the outer barrel is too large and won't sit in the tyre. I tried everything, taking it apart, trimming the tyre a bit but no luck so I removed the left wheel which was fine and took that apart to find that the same barrel on this side was smaller. In the pics the correct left wheel is on the left and the incorrect right wheel is on the right.
Dodge charger build complete
Steve279021
#2 Posted : 17 October 2025 13:29:01
The 2 barrels side by side
#3 Posted : 17 October 2025 14:18:37
Yes, that doesn't look right.
I had no problems with that stage so I suggest you contact c/s for a replacement.
Shouldn't be an issue.
Roy.
Steve279021
#4 Posted : 17 October 2025 14:41:20
Maybe i should ask for a stage 99 as 99 and 103 are the same but if they give me another 103 then I could get the same problem
Steve279021
#5 Posted : 30 October 2025 14:12:33
This is ridiculous, they've sent me another 103 and again, it's the same!!
In this pic, the one on the right is the stage 99 and the other 2 are the 2 103 stages.
#6 Posted : 30 October 2025 15:27:12
Can you post a full 'sideways on' picture of the wheels so we can see the differences up close?
It seems really strange.
Roy.
Steve279021
#7 Posted : 30 October 2025 17:48:54
I'm at work now so I'll do it tomorrow. I contacted cs and they said that they are going to send me a stage 99. Not sure that'll be any different as surely they come from the same machine. I reckon it's a bad batch.
DoubleK
#8 Posted : 30 October 2025 19:22:51
Rank: Member
I am going to check mine tonight. I haven't opened the pack because I am way behind on the build. If there is a problem, do you thibk Customer Support could help, even if I am out of the time they state you have to flag any problems??
Steve279021
#9 Posted : 31 October 2025 12:45:24
I've tried to get some better pics roy. Basically the plastic inner barrel is too large in stage 103 but correct size in stage 99.
Stage 99 is on the right
Steve279021
#10 Posted : 31 October 2025 12:46:16
Again, stage 99 on the right
Steve279021
#11 Posted : 31 October 2025 12:47:22
Stage 99 on top
Steve279021
#12 Posted : 31 October 2025 12:49:46
Steve279021
#13 Posted : 31 October 2025 13:02:49
Good idea. Let me know what you find👍
DoubleK
#14 Posted : 02 November 2025 13:41:40
Rank: Member
My 103 is indeed sticking out the same. Going to contact CS and ask for another 99.
Steve279021
#15 Posted : 03 November 2025 07:29:30
Cheers for checking that. This is a really odd issue as they should be the same. I've got another 99 on the way too so hopefully this will be ok🤞
DoubleK
#16 Posted : 03 November 2025 13:56:33
Rank: Member
I was a couple of days outside the 14 day complaint period, so here's hoping that someone who has stuck with this to the end can be helped ;)
***UPDATE*** They just said they would send another 103, despite me explicitly requesting a 99. I have replied again to politely ask if they can make it a 99 instead...
Steve279021
#17 Posted : 12 November 2025 16:56:40
UPDATE: I've received another stage 99 as a replacement for the 2 faulty stages 103. This part is the correct size so it seems that there is an issue just with stage 103. Which is odd as it is an identical stage. So who knows. Maybe others need to check this out too
DoubleK
#18 Posted : 12 November 2025 17:46:28
Rank: Member
They replied to me to say it will be a 99 rather than a 103 that I get too. I eagerly await its arrival!
DoubleK
#19 Posted : 26 November 2025 21:53:10
Rank: Member
The final pack, taking me up to 110 arrived yesterday. In a separate box, I had the replacement 99 for 103...AND a 103.
This means I ended up with two defective 103s...which I can use as a bitbof a "pit-style" backdrop for the model when complete.
Thank you DeAgostini 😀
Senna64
#20 Posted : 03 April 2026 13:14:13
Rank: Member
Hey guys. I received my Stage 19 Pack yesterday (Issues 99 to 104). I can also confirm my packs contained the same issue (Packs 99 and 103 differing in fitment). Thanks for the initial heads up Steve279021, I was able to compare quickly, and put in a request to CS at Dean for a replace 99 pack. Cheers.
This page was generated in 0.283 seconds.
