Peugeot 205 Dakar Turbo Official Build STAGES 39 - 42 Options
#1 Posted : 18 October 2025 13:47:45
STAGE 39A:
Left front transmission.
Pic 1: Locate the stub axle parts 39A and 39B and fit them together as shown
Pic 2: Retrieve the shaft 8D saved from stage 8 and fit it through the gaiter 39C and then the plate 39D.
Pic 3: Shows the parts fitted together.
Pic 4: Fit the assembly to parts 39A/B and fix together with 4 x AM screws.
Pic 5: Fit the wheel guard 39G as shown and fix with 2 x AP screws.
#2 Posted : 18 October 2025 13:51:39
STAGE 39B:
Pic 6: Press-fit the brake pipe connector 39F into the caliper 39E.
Make sure it is angled as shown.
Pic 7: Fix the caliper to the main assembly with 2 x AM screws.
Pic 8: Fit the narrow end of the upper arm 39H to the main assembly in the position shown and fix it with 1 x BM screw.
Pic 9: Fit the brake pipe 39J to the connector 39F.
Pic 10: Fit the support 39I to the assembly in the position shown and fix with 1 x ANM screw from the outside at each end.
#3 Posted : 19 October 2025 11:30:01
STAGE 40A:
Left front suspension.
Pic 1: Locate the spring and damper parts 40B, 40C, 40F and 40G.
Also, the build cradle 40I.
Pic 2: Using the cradle 40I, assemble the parts as shown, pressing one of the 40G pins into the hole in the end of 40B to lock the parts together.
Pic 3: Make two assemblies.
NOTE - Save the assembly cradle 40I for use in a future stage.
Pic 4: Retrieve the assembly from the previous stage and fit the shock absorbers/springs in place on the arm 39H as shown, fixing them using 1 x AM screw in each.
NOTE – the angled upper end of the shock absorber shown in red must be facing the way indicated.
Pic 5: Retrieve the main car assembly and fit the suspension in place on the front left side, fixing it with 2 x AM screws.
Pic 6: Fit the wheel arch 40A to the floor as shown, fixing it with 3 x AM screws.
#4 Posted : 19 October 2025 11:37:04
STAGE 40B:
Pic 7: From underneath, lift the suspension so that the two shock absorbers locate in the holes in the inside of the wheel arch 40A.
Pic 8: Fix the parts in place from above using 2 x AM screws.
Pic 9: With the model upside down, fit the lower suspension arm 6D into the hub upright as shown and fix with 1 x BM screw.
Make sure the drive shaft locates in the rubber gaiter circled.
Pic 10: Lift the steering arm 38H into position and fix it to the hub upright with 1 x BM screw.
Pic 11: From above, fix the front of the wheel arch 40A with 1 x AP screw.
Pic 12: Assemble the filler parts 40D and 40E and fit it to the locating hole in the wheel arch as shown, fixing it from underneath with 1 x AP screw.
Pic 13: Retrieve the disc assembly from stage 19 and fit it in place as shown, fixing it with the small black washer 40H and 1 x DM screw.
The printed instructions say you can now fit the front wheel using 4 x AM screws.
This has not been done here due to the added weight on the suspension and the risk of possible damage during the forthcoming build stages.
The wheels will be added at the end of the build.
This is of course entirely at the builder’s discretion.
#5 Posted : 20 October 2025 10:09:23
STAGE 41A:
Right front transmission.
Pic 1: Locate the stub axle parts 41A and 41B and fit them together as shown.
Pic 2: Retrieve the shaft 8D saved from stage 8 and fit it through the gaiter 41C and then the plate 41D.
Pic 4: Fit the assembly to parts 41A/B and fix together with 4 x AM screws.
Pic 5: Fit the wheel guard 41G as shown and fix with 2 x AP screws.
#6 Posted : 20 October 2025 10:12:26
STAGE 41B:
Pic 6: Press-fit the brake pipe connector 41F into the caliper 41E.
Pic 8: Fit the narrow end of the upper arm 41H to the main assembly in the position shown and fix it with 1 x BM screw.
Pic 9: Fit the brake pipe 41J to the connector 41F.
Pic 10: Fit the support 41I to the assembly in the position shown and fix with 1 x ANM screw from the outside at each end.
Pic 11: Locate the three disc parts 41J, 41K and 41L.
Pic 12: Press-fit the parts together in the order shown.
Store the assembly and disc safely for now.
#7 Posted : 21 October 2025 10:24:13
STAGE 42A:
Right front suspension.
Pic 1: Locate the spring and damper parts 42B, 42C, 42F and 42E.
Retrieve the build cradle 40I saved from stage 40.
Pic 2: Using the cradle 40I, assemble the parts as shown, pressing one of the 42E pins into the hole in the end of 42B to lock the parts together.
Pic 4: Retrieve the assembly from the previous stage and fit the shock absorbers/springs in place on the arm 41H as shown, fixing them using 1 x AM screw in each.
Pic 6: Fit the wheel arch 42A to the floor as shown, fixing it with 3 x AM screws.
#8 Posted : 21 October 2025 10:26:50
STAGE 42B:
Pic 7: From underneath, lift the suspension so that the two shock absorbers locate in the holes in the inside of the wheel arch 42A.
Pic 9: With the model upside down, fit the lower suspension arm 7D into the hub upright as shown and fix with 1 x BM screw.
Pic 10: Lift the steering arm 38I into position and fix it to the hub upright with 1 x BM screw.
Pic 11: From above, fix the front of the wheel arch 42A with 1 x AP screw.
This page was generated in 0.534 seconds.
