 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
Some work over the past 5 - 6 days... Start on the front frames shortly. roymattblack attached the following image(s):
Back on this one for a while now.
A lot of the engine is sorted and I've added the missing bits from the front firewall and engine frame.
The upper body is prepped and it's all in white primer at present. The inside of the body is now satin black, hence all the masking tape.
Once it's all in gloss white the tape will come off so I can add the windows and inner rear shelf.
Then the rear underside will be added, before I start work on the interior.roymattblack attached the following image(s):
A bit more...
Rear cage assembled.roymattblack attached the following image(s):
On we go...
Interior carpeted now. Dashboard etc next...roymattblack attached the following image(s):
RHD dashboard now sorted and fitted. Seats next and then engine area. roymattblack attached the following image(s):
