 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
I went to build stage 103, the right rear wheel, and found that the outer barrel is too large and won't sit in the tyre. I tried everything, taking it apart, trimming the tyre a bit but no luck so I removed the left wheel which was fine and took that apart to find that the same barrel on this side was smaller. In the pics the correct left wheel is on the left and the incorrect right wheel is on the right. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
The 2 barrels side by side Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,838 Points: 17,666 Location: ipswich
Yes, that doesn't look right. I had no problems with that stage so I suggest you contact c/s for a replacement. Shouldn't be an issue.
Roy.
Maybe i should ask for a stage 99 as 99 and 103 are the same but if they give me another 103 then I could get the same problem Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
This is ridiculous, they've sent me another 103 and again, it's the same!! In this pic, the one on the right is the stage 99 and the other 2 are the 2 103 stages. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Can you post a full 'sideways on' picture of the wheels so we can see the differences up close? It seems really strange.
Roy.
I'm at work now so I'll do it tomorrow. I contacted cs and they said that they are going to send me a stage 99. Not sure that'll be any different as surely they come from the same machine. I reckon it's a bad batch. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Member
Joined: 23/06/2025 Posts: 11 Points: 33 Location: Redditch
I am going to check mine tonight. I haven't opened the pack because I am way behind on the build. If there is a problem, do you thibk Customer Support could help, even if I am out of the time they state you have to flag any problems??
I've tried to get some better pics roy. Basically the plastic inner barrel is too large in stage 103 but correct size in stage 99. Stage 99 is on the right Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Again, stage 99 on the right Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 99 on top Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
DoubleK wrote:I am going to check mine tonight. I haven't opened the pack because I am way behind on the build. If there is a problem, do you thibk Customer Support could help, even if I am out of the time they state you have to flag any problems?? Good idea. Let me know what you find👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Member
My 103 is indeed sticking out the same. Going to contact CS and ask for another 99.
DoubleK wrote:My 103 is indeed sticking out the same. Going to contact CS and ask for another 99. Cheers for checking that. This is a really odd issue as they should be the same. I've got another 99 on the way too so hopefully this will be ok🤞 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Member
I was a couple of days outside the 14 day complaint period, so here's hoping that someone who has stuck with this to the end can be helped ;)
***UPDATE*** They just said they would send another 103, despite me explicitly requesting a 99. I have replied again to politely ask if they can make it a 99 instead...
UPDATE: I've received another stage 99 as a replacement for the 2 faulty stages 103. This part is the correct size so it seems that there is an issue just with stage 103. Which is odd as it is an identical stage. So who knows. Maybe others need to check this out too Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Member
They replied to me to say it will be a 99 rather than a 103 that I get too. I eagerly await its arrival!
Rank: Member
The final pack, taking me up to 110 arrived yesterday. In a separate box, I had the replacement 99 for 103...AND a 103.
This means I ended up with two defective 103s...which I can use as a bitbof a "pit-style" backdrop for the model when complete.
Thank you DeAgostini 😀
Rank: Member
Hey guys. I received my Stage 19 Pack yesterday (Issues 99 to 104). I can also confirm my packs contained the same issue (Packs 99 and 103 differing in fitment). Thanks for the initial heads up Steve279021, I was able to compare quickly, and put in a request to CS at Dean for a replace 99 pack. Cheers.
