 Rank: Master     Groups: Registered
Joined: 26/04/2014 Posts: 1,496 Points: 4,400 Location: Essex
Stage 99. Left rear wheel and tyre. I am not fitting this just yet as it will make it difficult fitting the wing in a couple of stages. I'll fit both wheels after that. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046
Stage 100. Right diffuser heat shields. That's the last time I need to flip it over!👍 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 101. Lower rear wing and support Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
Looking great Steve. There is more 'flipping it over' right at the end...
Cheers Roy. Looking forward to flipping it again🤦♂️. Stage 102, rear wing built and fitted and the left rear wheel fitted. I really can't understand why they tell you to put the left rear wheel on before mounting the wing. It would have been next to impossible! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Well stage 103 is finally done. The second wheel and tyre is actually another stage 99 as there seems to be an issue with stage 103 in that the plastic barrel is too large but stage 99 is fine even though it's an identical stage🤷♂️. Anyway it's done now and it's looking tough😲😲! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 104. Rear wheel centre caps. That's pack 19 done. Waiting on the final pack now. Pack 20. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
So here it is, the final pack. Pack 20 Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 105, seat and harnesses Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 106. Steering wheel and front wing end plate skid plates. I have decided not to install the display mounts on the bottom of the chassis for now as I think it'll look better on display without then. If it's an issue then I install them later Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I have now added the extra waterside decals to the chassis now as the chassis will no longer be visible on my build pics. Obviously I can't put the pics on here with them on but I will say that they look awesome👍 Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 107. Body nose and securing pins. The gaps in the clips were a bit large so I used some pliers to close up the gap otherwise the pins wouldn't have stayed in the clips Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 108, the big piece! Main body and nose fitted together Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Stage 109. Left rear winglet and mirrors fitted. 1 stage to go! Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Finished!!! Stage 110. Right rear winglet and windscreen fitted. Complete body fitted to chassis. Well what a fantastic build this has been and I've loved every minute of it. Gonna miss it but glad it's finished. I'm eyeing up the rb19 now🤔. Anyway, I hope you've all enjoyed the build too for the ones that have been following it and hope it encourages others to subscribe to it. Especially as its on offer at the moment👍. Here's the final pics. I'll be adding some special extra pics tonight so keep an eye out for them, they will be good😍. Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Well done there. It looks fantastic. By all means post pics with the decals added, but blur the decals as DeAgostini can't advertise on the website or forum.
I heartily go with the RB19 as it'as an amazing kit.
Roy.
Cheers Roy👍. Unfortunately I don't seem to be able to upload the other pics. They were the 97t sitting next to the mp4/4 and looked great. Not sure why but when I blurred out the decals on the mp4 the pics only came up as downloads so I've given up on that. Pity Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
I had to just cut the Pics right down to the best i could do. Also I weighed them both. Couldn't believe the difference Steve279021 attached the following image(s): Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Rank: Member
Joined: 23/06/2025 Posts: 11 Points: 33 Location: Redditch
Looks fab! How did you find the decals? And did you get that carrier film off?
I just finished the MP4/4 and had major problems with the Shell and Honda ones...so ended up having to use third-party ones.
