International Space Station Official Build - Pack 19 Options
#1 Posted : 01 January 2026 12:36:05
Issue 99
Fix piece 32A and 32D together using a AS5 screw, pictures 2 and 3. Take the previous assembly from the last issue and fix it to this assembly using 2 x AS5 screws, pictures 4 and 5.
Fix piece 32B to the assembly using a AS5 screw, picture 6. Push fit the part 31Z to cover the screws, picture 7.
Finally, attach the assembly to the main structure using an MS4 screw as illustrated in picture 8.
#2 Posted : 01 January 2026 12:48:13
Issue 100
Fix piece 32K and 32L together using a AS5 screw, pictures 2, 3 and 4.
Fix piece 32N to the assembly using a AS5 screw, picture 5. Place part 32M onto the assembly securing it in place with a AS5 screw, picture 6.
Picture 7 shows the assembly complete for this issue.
#3 Posted : 01 January 2026 12:51:04
Issue 101
Fit part 32H to the previous assembly from the last issue, the two parts will click into place, pictures 2 and 3. Attach part 32J to 32H as shown in picture 4, then secure in place using a AS5 screw, picture 5.
Attach part 32i to the assembly and secure this in place using a AS5 screw, pictures 6 and 7.
Push fit the part 31Z to cover the screws, picture 8.
Finally, attach the assembly to the main structure using an MS4 screw as illustrated in picture 9.
#4 Posted : 01 January 2026 12:55:00
Issue 102
Fix piece 28H to the assembly as shown in picture 2 using 2 x MS4 screws.
Finally, push fit the base end part onto the base, picture 3.
#5 Posted : 04 January 2026 13:55:59
Issue 103 Part 1
Take pieces 30Db and 30C and attach them together using an AS5 screw, pictures 2 and 3. Attach part 30E using an AS5 screw followed by parts 30F and 30G, pictures 4, 5 and 6.
Attach the assembly to the previous assembly you did in the last issue, using an AS5 screw, picture 7.
That completes part 1 of the assembly for this issue.
#6 Posted : 04 January 2026 13:58:06
Issue 103 Part 2
Take pieces 30Da and 30C and attach them together using an AS5 screw, picture 8. Attach part 30E using an AS5 screw followed by parts 30F and 30G, pictures 9, 10 and 11.
Attach the assembly as you did before, using an AS5 screw, picture 12.
Fix piece 27i to the main structure assembly using 2 x MS4 screws as shown in picture 13.
Finally, attach part 29C as illustrated in picture 14.
That completes part 2 of the assembly for this issue.
#7 Posted : 04 January 2026 14:01:41
Issue 104
Attach parts 33B and 33A together using an MS4 screw as shown in picture 2.
This page was generated in 0.654 seconds.
