Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
Issue 105
Picture 1 shows the contents of this issue. Attach part 33C to the previous assembly using an AS5 screw, pictures 2 and 3.
Attach piece 33D to the left-hand side of the assembly using 2 x AS5 screws, pictures 4 and 5.
Picture 6 shows the assembly complete.
Issue 106
Picture 1 shows the contents of this issue. Attach part 33E to the previous assembly using an AS5 screw, pictures 2 and 3.
Attach piece 33D to the middle of the assembly using 2 x AS5 screws, pictures 4 and 5.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 107
Picture 1 shows the contents of this issue. Attach piece 33D to the right hand-side of the assembly using 2 x AS5 screws, pictures 2 and 3.
Issue 108
Picture 1 shows the contents of this issue. Fit piece 27U to the previous assembly using an MB4L screw as illustrated in picture 2.
Attach the two 27V parts as shown in picture 3.
Issue 109
Picture 1 shows the contents of this issue. Fit piece 27J to the previous assembly using 4 x MS4 screws as illustrated in picture 2.
Position the module assembly from issue 94 as shown in picture 3 and attach the array assembly to the main structure assembly using 6 x MS4 screws, picture 4. Attach the clip piece, 29D over the screws in the running frame, picture 5.
Issue 110
Picture 1 shows the contents of this issue. Fit piece 27K to the previous assembly using 2 x MS4 screws as illustrated in picture 2.
Cover the screws by push fitting the two 27L pieces in place as illustrated in picture 3.
Attach part 29E to the assembly, picture 4.
