Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
Issue 111
Picture 1 shows the contents of this issue. Attach part 33B to 33A using an MS4 screw, picture 2.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 112
Picture 1 shows the contents of this issue. Attach part 33C to the previous assembly using an AS5 screw, picture 2.
Attach piece 33D to the left hand-side of the assembly using 2 x AS5 screws, picture 3.
Issue 113
Picture 1 shows the contents of this issue. Attach part 33E to the previous assembly using an AS5 screw, picture 2.
Attach piece 33D to the middle of the assembly using 2 x AS5 screws, picture 3.
Issue 114
Picture 1 shows the contents of this issue. Attach piece 33D to the right hand-side of the assembly using 2 x AS5 screws, picture 2.
Issue 115
Picture 1 shows the contents of this issue. Fit piece 33H to the previous assembly using an MB4L screw as illustrated in picture 2.
Attach the two 27V parts as shown in picture 3.
Issue 116
Picture 1 shows the contents of this issue. Fit piece 27N to the previous assembly using 4 x MS4 screws as illustrated in picture 2.
Attach the array assembly to the main structure assembly using 6 x MS4 screws, picture 3.
Attach the clip piece, 29F over the screws in the running frame, picture 4.
