International Space Station Official Build - Pack 22 Options
#1 Posted : 04 January 2026 15:59:03
Issue 117
Fit piece 27O to the previous assembly using 2 x MS4 screws as illustrated in picture 2.
Cover the screws by push fitting the two 27L pieces in place as you did before.
Attach part 29G to the assembly, picture 3.
Finally, attach the two 33B pieces as illustrated in picture 4.
#2 Posted : 04 January 2026 16:06:43
Issue 118
Insert one of the Base 07 parts into the base and attach base 09 to the top, picture 2. Do the same on the other side of the base, picture 3.
Fix the assembly you’ve done over the last few issues and place it on the main structure as illustrated in picture 4, securing it in place using 2 x MS4 screws.
Picture 5 shows the assembly attached.
#3 Posted : 04 January 2026 16:11:52
Issue 119
Fix the two 27Y pieces to 27X using an AS5 screw in each one, pictures 2 and 3.
Attach the assembly to the main structure using 4 x MS4 screws as shown in picture 4.
#4 Posted : 04 January 2026 16:22:38
Issue 120
The last issue that completes this fabulous model.
Attach the assembly from issue 103 to the arm, using an AS5 screw as shown in picture 2.
Take the solar panel structures, picture 3 and insert them in each end of the structure, screwing them up to the stop, picture 4. Fix one of the 33A pieces in place and secure it using 2 x MS4 screws, as also shown in picture 4.
Do the same with the opposite end.
You have now completed the ISS.
For those who have subscribed to the premium base, I will be illustrating how the base is put together in the next chapter.
This page was generated in 0.163 seconds.
