Premium Base Instructions Part 1
There are 10 separate issues for the premium base. The parts must be done in order and attached in order as I will show you. So, let’s get started.
Take issue 1 and start by attaching the white lighting part to the outer frame, securing it in place using five of the A screws provided, pictures 1 and 2.
Take the second issue and do the same using the five screws to attach the parts together, picture 3 and 4.
Attach the two outer frames together using 2 x A screws. Assembling the outer frame does not need to be in order as all the parts are the same, picture 5.
Attach the two bottom parts of the base as shown in picture 6. Note the order they go in. You must assemble this part of the base in sequence as the cable are of different sizes in each frame segment.
The process is the same with issue 3, pictures 7, 8 and 9. Picture 10 shows the sequence of the base parts.
That completes Part 1 of the Premium Base.
Premium Base Instructions Part 2
Picture 11 shows the contents of issue 8.
As before, secure the inner lighting part to the outer frame, picture 12.
Fix the circuit board into the frame number 8, securing it with the two screws provided, picture 13. Attach the final frame to the rest as shown in picture 14. Note, you will see the sequence of all the parts put together. As also shown in picture 14, feed the cables around the base, slotting them into the post to secure them in place.
Connect all the cables as seen in the diagram in picture 15.
Take the centre panel, and on the inside place the bolt into the hole as shown in picture 16. Secure this in place by attaching the cover using 2 x A screws, picture 17. Turn the assembly over and attach the battery cover with the screw provided picture 19.
Secure the centre panel to the outer base by using 14 type A screws as shown in picture 20. Turn the assembly over again and connect the battery cable into connector 10, picture 21.
That completes part 2 of the Premium Base assembly.
Premium Base Instructions Part 3
Attach the lighting board to the inner centre panel as illustrated in picture 22. Take the cable from the circuit board and connect it the circuit board in connector 11 as shown in picture 23.
Place the printed star base top and place it into the outer frame slotting it into the 16 posts as illustrated in picture 24. Fit this to the bottom base and secure it using 16 screws provided, picture 25.
You also get a new set of black pegs that hole the ISS in place on the base. These are identical to the ones on the normal base. Put them into the same position as the normal base and carefully transfer the ISS model onto the new base.
That completes the Premium Base instructions.
The final picture shows the ISS on the Premium Base.
