Ferrari 330 P4 Official Build stages 57 - 62 Options
#1 Posted : 08 January 2026 12:12:32
STAGE 57:
Chassis frames.
Pic 1: NOTE: The printed instructions tell you to check the large end of the engine mount is facing rear – circled.
The previous printed instructions for this part were incorrect but if you have been following this build you will have fitted the part correctly.
Locate the frame part 57A.
Pic 2: A close up of the correctly fitted engine mount.
Pic 3: Fit the frame 57A as shown and fix at the rear with 1 x AM screw.
Pic 4: Fit the frame 57B on the other side in the same way and fix at the rear with 1 x AM screw.
Pic 5: Store the parts safely for now.
#2 Posted : 09 January 2026 11:03:37
STAGE 58:
Chassis frames 2.
NOTE: It is strongly advised that you DO NOT build this stage until AFTER stage 62, when the exhausts will be fitted.
If you build this stage now, you will need to remove the parts again or you will find it almost impossible to attach the manifolds to the engine.
Pic 1: Locate arm 58A. You will see that one end has a small ‘L’ on it.
Pic 2: Fit the bracket 58B to the end of the arm with the ‘L’, noting the slight angle on each end of the arm 58A.
This is important.
Fix the parts with 1 x ABM screw.
Take care here as the screws in this build stage are a tight fit and you may need to tap or enlarge all the holes.
Pic 3: Retrieve the engine assembly and fit the arm in place as shown, fixing it with 1 x BM screw next to the bottom of the shock absorber.
The arm should be angled in, towards the engine.
Pic 4: Fit the short arm 58C to one end of the arm 58D as shown, taking note again of the angle of the parts.
Fix with 1 x ABM screw.
Pic 5: Fit the end of the arm 58D to the top of the rear hub and fix with 1 x BM screw.
Fit the end of the shorter arm 58C to the engine mount – circled – and fix with 1 x AM screw.
The next steps can be done now if you wish.
Pic 6: Fit the connector 58E to the end of the pipe 58F as shown.
Pic 7: Retrieve the central frame assembly and fit the pipe 58F as shown, passing it under the alternator.
Pic 8: Retrieve hose 57C from the previous stage and fit it to the pipe end as shown.
Store the model safely.
#3 Posted : 10 January 2026 11:54:39
STAGE 59:
Chassis frames 3.
NOTE: As with stage 58, it is strongly advised that you DO NOT build this stage until AFTER stage 62, when the exhausts will be fitted.
Pic 1: Fit the bracket 59B to the end of the arm 59A, noting the slight angle on each end of the arm.
This is important.
Pic 2: Detail of the fixing.
Pic 3: Retrieve the engine, noting where the arm will fit.
Pic 4: Fit the arm as shown and fix with 1 x BM screw.
Pic 5: Fit the short arm 59C to one end of the arm 59D as shown, taking note again of the angle of the parts.
Pic 6: Fit the end of the arm 59D to the top of the rear hub and fix with 1 x BM screw.
Fit the end of the shorter arm 59C to the engine mount and fix with 1 x AM screw.
Pic 7: Detail of the engine mount fixing.
Pic 8: Locate the gear rod 59E.
It will fit in the direction shown.
Pic 9: Feed the gear rod through the suspension so that the rear end will connect to the gear selector bracket.
The front end will attach to the end of the previously fitted suspension arm.
Pic 10: Fix at the rear with 1 x BM screw.
Pic 11: Fix at the front end with 1 x ABM screw.
#4 Posted : 12 January 2026 13:17:42
STAGE 60A:
Left exhaust.
Pic 1: Press-fit the exhaust parts 60A and 60B together.
Pic 2: Fix the 3 x flanges 60 F to the three manifold pipes 60C, 60D and 60E as shown using 1 x MP screw in each.
Do not fully tighten the screws.
Pic 3: Retrieve the main exhaust pipe and fit the manifold pipe 60C as shown.
Pic 4: Fit the pipe 60D as shown.
NOTE: The printed instructions show this pipe going behind 60C.
This is incorrect.
Pic 5: Fit the pipe 60E as shown.
Pic 6: Fix the small bracket 60Kto the main pipe using 1 x MP screw.
Then fit the coupling 60G as shown, fixing it with 1 x AQM screw.
#5 Posted : 12 January 2026 13:20:20
STAGE 60B:
Pic 7: Retrieve the exhaust assembly from stage 55.
Pic 8: Fit the two assemblies together as shown and fix using 1 x MP screw through bracket 55H.
Pic 9: Fix the ends of the exhausts together using 1 x MP screw.
Pic 10: Locate the heat shield 60H.
It will press-fit in the locations indicated.
Pic 11: Heat shield in place.
Pic 12: Store all parts and the unused screws safely for now.
#6 Posted : 13 January 2026 10:12:23
STAGE 61A:
Right exhaust.
Pic 1: Press-fit the exhaust parts 61A and 61B together.
Pic 2: Fix the 3 x flanges 61 F to the three manifold pipes 61C, 61D and 61E as shown using 1 x MP screw in each.
Pic 3: Retrieve the main exhaust pipe and fit the manifold pipe 61C as shown.
Pic 4: Fit the pipe 61D as shown.
Pic 5: Fit the pipe 61E as shown.
Pic 6: Fix the small bracket 61Kto the main pipe using 1 x MP screw.
Then fit the coupling 61G as shown, fixing it with 1 x AQM screw.
#7 Posted : 13 January 2026 10:18:45
STAGE 61B:
Pic 7: Retrieve the exhaust assembly from stage 56.
Pic 8: Fit the two assemblies together as shown and fix using 1 x MP screw through bracket 56H.
Pic 10: Locate the heat shield 61H.
#8 Posted : 14 January 2026 11:18:00
STAGE 62A:
Fitting the exhausts.
NOTE: If you fitted the suspension parts in stages 58 and 59 you will find fitting the exhausts to the engine almost impossible.
Working on one side at a time, you will find it easier to remove the suspension parts, keeping them and the screws safely to one side and then re-fitting them after the exhaust is fitted.
The assembly here shows the suspension parts removed and re-fitted afterwards.
Pic 1: Retrieve the engine assembly and fit the bracket 60J to the hanger 53B using 1 x AQM screw.
Pic 2: This shows the suspension parts highlighted in yellow that you can remove to make the following steps easier.
As already stated, this is at the builder’s discretion.
DO NOT lose any parts or fixing screws.
Pic 3: Fit the exhaust in place and secure the hanger 60G to the bracket 16A with 1 x QM screw.
Pic 4: From underneath, fix the end of the exhaust with 1 x MP screw.
Pic 5: Fit the front manifold to the engine and secure with 1 x MP screw.
Pic 6: Detail of the fixing.
#9 Posted : 14 January 2026 11:21:00
STAGE 62B:
Pic 7: Working from the front, connect each manifold to the engine using 2 x MP screws.
This is actually quite easy.
Pic 8: If you removed them, re-fit the suspension parts as indicated.
Pic 9: Press-fit the heat shield 54B in place.
Pic 10: From underneath, fit the support arm 60I.
Pic 11: On the other side of the engine fit the panel 53F as shown and fix with 5 x QM screws.
Pic 12: Fix the bracket 61J to the hanger 53B with 1 x AQM screw.
#10 Posted : 14 January 2026 11:23:45
STAGE 62C:
Pic 13: Fit the exhaust in place and fix the hanger 61G to the bracket 20A with 1 x QM screw.
Pic 14: From underneath, fix the end of the exhaust with 1 x MP screw.
Pic 15: As before, fix the front manifold using 1 x MP screw.
Pic 16: Working from the front, connect each manifold to the engine using 2 x MP screws.
Pic 17: Re-fit the suspension parts if you removed them.
Pic 18: Press-fit the heat shield 54A in place.
Pic 19: From underneath, fit the support arm 61I.
Store the model and unused wheel parts safely.
This page was generated in 0.274 seconds.
