Red Bull RB19 Official build. Stages 39 - 44 Options
#1 Posted : 15 January 2026 12:43:18
STAGE 39A:
Left radiator 3.
Pic 1: Retrieve the assembly from stage 36 and locate the pipes 39A and 39B.
Pic 2: Press-fit the pipes in place as shown.
Pic 3: Fit the radiator from stage 38 and fix from underneath with 2 x ‘A’ screws.
Pic 4: Fit the manifold 39C in place.
Pic 5: Fix from behind with 1 x ‘E’ screw and 1 x ‘A’ screw.
Pic 6: Locate the support 39E and the tubes numbered 1 and 2.
#2 Posted : 15 January 2026 12:45:40
STAGE 39B:
Pic 7: Attach one of the ‘1’ tubes and the ‘2’ tube as shown.
Pic 8: Fix the support to the main panel using 1 x ‘G’ screw from behind.
Pic 9: Connect the ends of the tubes to the manifold as shown.
Pic 10: Pass another ‘1’ tube (highlighted in grey) through the hole in the support nearest to the panel and connect each end where indicated.
Pic 11: Fit another ‘1’ tube (highlighted in grey) through the other hole in the support and connect each end as indicated.
Pic 12: Fit one of the short ‘5’ tubes to the pins on the manifold and tank as shown.
Pic 13: Store the assembly and unused parts safely.
#3 Posted : 16 January 2026 10:28:27
STAGE 40:
Right panel.
Pic 1: Retrieve the unused parts from the previous stage.
Connect tubes ‘4’ and ‘5’ to the union 39D.
Pic 2: Connect tube ‘3’ to the union 39D.
Pic 3: Retrieve the left radiator assembly and press-fit the union 39D in place where shown.
The long tube ‘3’ will pass through the slot at the bottom of the support, indicated by the smaller circle.
Pic 4: Connect tube ‘3’ as indicated.
Pic 5: Connect tube ‘4’ where shown.
NOTE – The printed instructions show this connection to be in the wrong place.
Pic 6: Locate parts 40A and 40B. They will press-fit together.
Pic 7: Parts assembled.
Store all parts safely for now.
#4 Posted : 17 January 2026 12:01:45
STAGE 41:
Right radiator.
Pic 1: Locate the two radiator parts 41A and 41B.
Pic 2: Fit the parts together as shown and fix with 2 x ‘A’ screws.
#5 Posted : 18 January 2026 17:41:22
STAGE 42:
Right radiator 2.
Pic 1: Retrieve the radiator 41A from the previous stage.
Radiator 42B will fit on top.
Pic 2: Parts fitted together.
Pic 3: Fit the panel 42A in place and fix with 2 x ‘A’ screws.
Store safely for now.
#6 Posted : 09 February 2026 11:29:06
STAGE 43A:
Right radiator 3.
Pic 1: Fit the two cooling pipes 43A and 43B to the assembly 40A.
They will only fit one way.
Pic 2: Retrieve the radiator assembly and fit it in place, fixing with 2 x ‘A’ screws from underneath.
Pic 3: Fit the cooling manifold 43C to the front of the assembly and fix from behind with 1 x ‘A’ screw.
Pic 4: Fit tube 43F (labelled 7) to the pin on the support 43E.
Pic 5: Fit the other end of the tube to the pin indicated on the manifold.
#7 Posted : 09 February 2026 11:31:30
STAGE 43B:
Pic 6: Fit the support to the assembly as shown and fix from behind with 1 x ‘G’ screw.
Pic 7: Detail of fixing.
Pic 8: Pass 2 x ‘1’ tubes through the two holes in the rear of the support and 1 x ‘8’ tube through the hole near the front.
Connect the tubes to the relevant pins as indicated.
NOTE: You may find it easier to disconnect the support from the assembly for better access to the pins, then re-fix it afterwards.
Pic 9: Connect the other ends of the tubes to the manifold as shown.
Pic 10: Fit the two tubes 43I (2) and 43H (9) to the connector 43D.
Each tube will only fit in one place.
Pic 11: Press-fit the connector in place at the front of the assembly and connect the two tubes where indicated.
Pic 12: Fit the 4 x tubes ‘10’ to the four sets of pins on the assembly as shown.
Store the parts safely for now.
#8 Posted : 10 February 2026 10:34:14
STAGE 44:
Rear left suspension 1.
Pic 1: Fit the support bracket 44B to the fairing 44A as shown and fix with 1 x ‘A’ screw.
Pic 2: Fit the narrow end of the arm 44C through the inner slot on the fairing where shown.
Pic 3: Fit the cranked end of the arm 44D through the outer slot in the fairing as shown.
Pic 4: From the other side, fix the two arms in place with 2 x ‘Q’ screws.
Store the parts safely.
This page was generated in 0.221 seconds.
