Ducati Desmosedici GP23 Issues 6 to 8 Options
#1 Posted : 17 January 2026 17:09:34
Issue 6
Take the crank case cover (6B) and fit the oil filter using a BP screw, pictures 2 and 3. Picture 4 shows the assembly complete.
Fit the oil filter cover (6D) using 2 x KP screws, picture 5. Fit the crankcase oil filter assembly to the crankcase (6A), picture 6, using 5 x AM screws. Start by fitting two of the screws as shown in picture 7, followed by the remaining three screws, picture 8.
#2 Posted : 18 January 2026 13:35:54
Issue 7 Part 1
Start by assembling the cylinder crank case (7B) and the engine crankcase (7C) together using 2 x AP screws, pictures 2 and 3. Now add the next cylinder crankcase (7D) to the assembly, picture 4. Place an AP screws as illustrated in picture 5, followed by a further two AP screws, picture 6.
Add the engine crankcase (7A) to the assembly, picture 7, and secure the assembly using 3 x AM screws as shown in picture 8. Finish securing the assembly by placing a UP screw in place as illustrated in picture 9.
That completes part 1 of this assembly.
#3 Posted : 18 January 2026 13:38:31
Issue 7 Part 2
Retrieve the crankcase assembly from issue 6 and join it to this assembly, picture 10. Place 4 x CM screws as shown in picture 11, then 3 x UP screws shown in picture 12.
Next place an AM screw on the inside as illustrated in picture 13, followed by another AM screw, further back on the inside, picture 14.
Push fit ferrule (7E) in place, picture 15. Finally attach the mounting pipe (7F) onto the assembly as shown in picture 16.
Picture 17 shows the complete assembly for part 2 of this issue.
#4 Posted : 19 January 2026 20:53:31
Issue 8
Retrieve the crankcase assembly from last time and attach the upper suspension anchor (8A) using 3 x EM screws, pictures 2 and 3.
Now take the suspension joint (8C) and the lower suspension anchor (8B), picture 4. Using the ANM screw attach the two parts together as shown in picture 5.
Match the four holes in the crankcase and match them to the anchor, picture 6. Secure this in place using 4 x EM screws, picture 7.
This page was generated in 0.195 seconds.
