World of Warcraft Lich King Pack 7 Options
#1 Posted : 17 January 2026 17:18:51
Issue 27
The Right Ankle
Place one of the spacers (27D) into both halves of the right ankle (27A & B), pictures 2, 3 and 4.
Retrieve the completed ankle joint from issue 25 and place its smooth circular end between the two discs of the left ankle (27C), picture 5. Secure the two parts using the hexagonal screw, two washers and the nut as shown in picture 6.
Finally, cover the assembly with the two halves of the ankle covers. Note the part 27C has a pin at the end, this goes into the half with the slot, pictures 7 and 8.
#2 Posted : 18 January 2026 13:44:51
Issue 28
The Right Calf
Retrieve the ankle assembly from the last issue. Place this in the narrowest part of the left calf (28A), picture 2. Secure it in place using a GM screw at the back of the ankle assembly and 2 x EM screws at the front, picture 3.
Picture 4 shows the complete assembly for this issue.
#3 Posted : 21 January 2026 19:27:58
Issue 29
The Right Leg and Knee
Insert the locking piston (29C) into the joint housing (29A). Insert the spring (29D), pictures 2 and 3. Close the housing with the cover (29E) and secure it using 2 x HM screws, picture 4.
Position the gear (29B) on the joint, and align the hole and insert the pin in the two parts, pictures 5 and 6.
Place the joint assembly into the assembly from the previous issue, securing it in place using 3 x EM screws, picture 7.
Assemble the joint covers (29G and 29H) and secure them together using a JP screw, picture 8.
Place the cover over the joint in the housing and secure using 2 x JM screws to the front and a KM screw at the back, picture 9.
Picture 10 shows the complete assembly for this issue.
#4 Posted : 22 January 2026 19:29:52
Issue 30
Place the front of the left leg (30A) onto the assembly from the previous issue and secure it in place using 6 x KP screws, picture 2.
Picture 3 shows the complete assembly for this issue.
#5 Posted : 23 January 2026 10:29:49
Issue 31
The Leg Assembly
Take the left mounting cover (31A), the one with an ā€œLā€ printed inside and place the left support block (31C) inside, picture 2.
Retrieve the leg assembly you built in issue 13 and the hip assembly from issue 21. Place the leg assembly into the hip assembly at the knee joint and place the cover assembly over the joint securing it place using 4 x GM screws, pictures 3 and 4.
Place the right block support into the front cover, picture 5, and repeat the process again as you did with the left side, picture 6.
#6 Posted : 27 January 2026 18:51:46
Issue 32
The Leg Assembly
Place the front of the left leg (32A) onto the assembly made in issue 31, picture 2. Secure it in place using 4 x LP screws, picture 3.
Do the same with the right front part (32B), securing it in place with 4 x LP screws, picture 4.
This page was generated in 0.223 seconds.
