Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,361 Points: 22,390 Location: Northamptonshire, England
Issue 6
Picture 1 shows the parts for this issue. Take the crank case cover (6B) and fit the oil filter using a BP screw, pictures 2 and 3. Picture 4 shows the assembly complete.
Fit the oil filter cover (6D) using 2 x KP screws, picture 5. Fit the crankcase oil filter assembly to the crankcase (6A), picture 6, using 5 x AM screws. Start by fitting two of the screws as shown in picture 7, followed by the remaining three screws, picture 8.
Picture 9 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 7 Part 1
Picture 1 shows the parts for this issue. Start by assembling the cylinder crank case (7B) and the engine crankcase (7C) together using 2 x AP screws, pictures 2 and 3. Now add the next cylinder crankcase (7D) to the assembly, picture 4. Place an AP screws as illustrated in picture 5, followed by a further two AP screws, picture 6.
Add the engine crankcase (7A) to the assembly, picture 7, and secure the assembly using 3 x AM screws as shown in picture 8. Finish securing the assembly by placing a UP screw in place as illustrated in picture 9.
That completes part 1 of this assembly.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 7 Part 2 Retrieve the crankcase assembly from issue 6 and join it to this assembly, picture 10. Place 4 x CM screws as shown in picture 11, then 3 x UP screws shown in picture 12. Next place an AM screw on the inside as illustrated in picture 13, followed by another AM screw, further back on the inside, picture 14.
Push fit ferrule (7E) in place, picture 15. Finally attach the mounting pipe (7F) onto the assembly as shown in picture 16.
Picture 17 shows the complete assembly for part 2 of this issue.
Issue 8
Picture 1 shows the parts for this issue. Retrieve the crankcase assembly from last time and attach the upper suspension anchor (8A) using 3 x EM screws, pictures 2 and 3.
Now take the suspension joint (8C) and the lower suspension anchor (8B), picture 4. Using the ANM screw attach the two parts together as shown in picture 5.
Match the four holes in the crankcase and match them to the anchor, picture 6. Secure this in place using 4 x EM screws, picture 7.
Picture 8 shows the complete assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
