Toyota Supra F+F Issues 39 - 44 Options
#1 Posted : 15 January 2026 13:31:13
STAGE 39:
Exhaust 2.
Pic 1: Retrieve the main assembly and carefully place it upside down.
Fit the exhaust 39B in place and fix with 2 x IM screws.
Pic 2: Retrieve the exhaust assembly 38C/38F.
The printed instructions suggest removing the top turbo cover to fit the exhaust in place but this isn’t really necessary as the parts fit together easily.
‘Wiggle’ the exhaust 38C into place under the sub frame and fit the end into the turbo as shown.
Pic 3: Shows the connection of the other end.
Pic 4: Parts in place, seen from above.
If you removed the turbo cover, re-fit it now.
Pic 5: Store the model and unused parts safely.
#2 Posted : 16 January 2026 14:53:51
STAGE 40:
Exhaust 3.
Pic 1: Fix the muffler part 40B to the exhaust 40A using 1 x CP screw.
There is an arrow moulded inside 40B which must face the rear.
Pic 2: Fix the tail pipe 40E in place with 1 x CP screw.
Pic 3: Fix the muffler part 40C in place with 2 x CP screws.
Pic 4: Fit the bracket 40D to the muffler and fix with 1 x CP screw.
The bracket will only fit one way.
Pic 5: Retrieve the main assembly and carefully place it upside down.
Fit the exhaust assembly as shown and fix with 1 x AM screw at the front and 1 x CP screw through the bracket at the rear.
Pic 6: Retrieve the exhaust 39A from the previous stage and fix it in place as shown using 3 x CP screws.
Pic 7: Press-fit the heat shield 39C from the previous stage in place.
Store the model safely.
Be careful as the model is heavy and will now be resting on the exhaust at the rear.
#3 Posted : 17 January 2026 13:14:18
STAGE 41:
Speaker and battery box.
Pic 1: Locate the fuel tank 41B, speaker 41C and bracket 41E.
Pic 2: Fit the parts together as shown and fix with 2 x GP screws.
Pic 3: Fit the battery box 41F and fix with 4 x GP screws.
Pic 4: Fit the switch 41D in place and fix with 2 x GP screws.
Note the wires are to the left on the switch.
Pic 5: Retrieve the fuel tank top from stage 37 and pass the wires through the square hole as indicated.
Pic 6: Fit the parts together and fix with 4 x IP screws.
Pic 7: Retrieve the fuel pipe section from stage 37 and fix it in place with 2 x AP screws.
Pic 8: Clip-fit the battery cover 41A in place.
Pic 9: Retrieve the main assembly and fit the fuel tank in place as shown.
The wires will pass through the hole in the floor panel.
Pic 10: From the other side, fix with 4 x IP screws.
Note the wires coming through the hole in the floor.
#4 Posted : 18 January 2026 17:24:22
STAGE 42:
Main PCB.
Pic 1: Fix the PCB 42A to the floor of the car as shown.
Make sure it is facing the right way.
Fix with 4 x GP screws.
Pic 2: Connect the plugs/wires from the fuel tank – J, K and L, to their respective sockets on the PCB.
Pic 3: Connect plug/wire A to the matching socket.
Pic 4: Connect plug/wire B to the matching socket.
Pic 5: Connect plug/wire D to the matching socket.
#5 Posted : 19 January 2026 11:53:30
STAGE 43:
Wiring 1.
Pic 1: Connect plug/wire C to the matching socket on the PCB.
Pic 2: Connect plug/wire E to the matching socket.
Pic 3: Connect plug/wire F to the matching socket.
Pic 4: Connect plug/wire G to the matching socket.
Pic 5: Connect plug/wire H to the matching socket.
#6 Posted : 20 January 2026 10:15:12
STAGE 44:
Wiring 2.
Pic 1: Connect wires 1, 2, 3 and Q in order, to the small PCB 44E.
Pic 2: Connect plug/wire Q to the matching socket on the main PCB.
Pic 3: Connect plug/wire R to the matching socket.
Pic 4: Connect plug/wire O to the matching socket.
Pic 5: Connect plug/wire M to the matching socket.
Pic 6: Connect plug/wire P to the matching socket.
Pic 7: Connect plug/wire N to the matching socket.
Pic 8: Connect plug/wire I to the matching socket.
