 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,805 Points: 17,567 Location: ipswich
STAGE 9:
Turbine engine 5.
Pic 1: Fit the fan 9-2 onto the shaft 9-1 as shown. Fan 9-3 will go on next.
Pic 2: Parts assembled.
Pic 3: Fit one of the exhaust fans 9-4 onto the other end of the shaft as shown.
Pic 4: Fit the other 4 x fans 9-4 as shown.
STAGE 10A:
Turbine engine 6.
Pic 1: Fit the bracket 10-6 over the turbine assembly as shown. The part will only fit neatly one way. Fix from underneath with 2 x ‘D’ screws.
Pic 2: Screw fixings.
Pic 3: Locate the motor 10-1 and the adhesive pad 10-7.
Pic 4: Peel the backing from the pad and stick it around the motor as shown. NOTE – you may find the pad doesn’t stick very well and you might need to use a very small amount of adhesive at each end, applied extremely carefully as it must not get inside the motor. This is entirely at the builder’s discretion.
Pic 5: Retrieve the turbine housing and fit the motor in place where indicated.
Pic 6: Fit the retaining bracket 10-2 and fix with 2 x ‘D’ screws.roymattblack attached the following image(s):
STAGE 10B:
Pic 7: Retrieve the inner assembly from stage 9 and locate the 3 x blades 10-3.
Pic 8: Fit the blades to the shaft in the same way as before.
Pic 9: Retrieve the housing assembly from stage 7 and fit 2 x small pipes 10-4 as shown.
Pic 10: Fit the other 2 x 10-4 pipes to the other side.
Pic 11: Fit the 4 x larger pipes 10-5 into the housing as shown, two on each side.
Pic 12: Store all parts safely for now.
STAGE 11 : Turbine engine 7.
Pic 1: Press-fit the 5 x oil pipes 11-2 into the housing 11-1 as shown.
Pic 2: Retrieve the assemblies’ 10-C and 10-D and fit them together.
Pic 3: Fit the upper housing in place on the lower assembly.
Pic 4: Fix the parts together with 4 x ‘D’ screws where indicated.
Store the parts safely for now.
STAGE 12:
Turbine engine 8.
Pic 1: Fit the fan 12-2 into the combustion chamber 12-1 and fix with 4 x ‘D’ screws.
Pic 2: Retrieve the main turbine assembly from the previous stages. The combustion chamber will fit over the shaft indicated.
Pic 3: Parts clip-fitted together. The parts will only fit one way.
Pic 4: Retrieve the assembly from stage 10. It will also clip-fit to the main assembly.
Pic 5: Parts clip-fitted together. The parts will only fit one way.
Pic 6: Fit the manifold 12-3 as shown.
Pic 7: Fit the manifold 12-4 as shown.
Store the assembly safely.
STAGE 13:
Left rear suspension.
Pic 1: Fit the bracket 13-4 to the suspension arm 13-3 in the direction shown and fix with 1 x ‘F’ screw from the ‘flat’ side of the bracket.
Pic 2: Fit the shock absorber assembly 13-2 to the arm as shown and fix with 1 x ‘F’ screw from the side indicated.
Pic 3: Fit the tilt frame/hub upright in place as shown and fix through the underneath with 1 x ‘G’ screw.
Pic 4: A different view of the assembly.
STAGE 14:
Left rear brake.
Pic 1: Fit the caliper 14-6 to the assembly from stage 13 and fix with 1 x ‘A’ screw. NOTE – The printed instructions incorrectly call the screw ‘F’.
Pic 2: Press-fit the back plate 14-4 into place.
Pic 3: Locate the disc halves 14-1 and 14-2. They will fit together face to face.
Pic 4: Parts assembled.
Pic 5: Peel the backing paper from the metal disc face 14-3 and stick it to the disc as shown.
Pic 6: Fit the disc centre 14-5 in place and fix from behind with 2 x ‘I’ screws.
Pic 7: Store the parts safely for now.roymattblack attached the following image(s):
