Chevrolet Nascar Official Build stages 51 - 56 Options
#1 Posted : 03 February 2026 16:37:48
STAGE 51:
Rear parcel shelf.
Pic 1: Retrieve the main assembly and fit the fuel cell retaining rack in place, noting how the 3 x pipes go through the centre.
Pic 2: With the rack positioned as shown, fix it down with 4 x JM screws.
Pic 3: Connect the silver fuel hose as shown.
Pic 4: Retrieve the rear subframe loop 48A saved from stage 48 and fit the support 51C in place as shown.
Fix it with 1 x EP screw.
Pic 5: Fit the support 51B in place as shown.
Pic 6: Fit the assembly in place on the rear deck of the car where indicated.
Pic 7: Carefully place the model upside down taking care not to put the model weight on the rear ‘V’ tubes on the subframe loop.
Fix where indicated with 2 x CM screws and 3 x EP screws.
Pic 8: Fix the other side using 1 x CM screw and 1 x EP screw as shown.
NOTE – The printed instructions incorrectly tell you to use a CM screw where it should be EP.
A CM screw is too small.
Pic 9: With the model the right way up, fit the parcel shelf 51D in place and fix with 2 x AM screws and 4 x AP screws where indicated.
Store the model safely.
#2 Posted : 04 February 2026 11:18:57
STAGE 52:
Rear lower subframe.
Pic 1: Fit the chain 52D to the INSIDE FACE of the bracket 52D and fix with 1 x AFM screw.
Pic 2: Repeat with the bracket 52C.
Pic 3: Fit the bracket/chain 52B to the frame 52A as shown and fix with 2 x CM screws.
Pic 4: Close up of assembly.
Pic 5: Repeat on the other side with bracket/chain 52C.
Store the parts safely for now.
#3 Posted : 05 February 2026 10:23:19
STAGE 53:
Rear brake lines.
Pic 1: Retrieve the frame 52A from the previous stage and fit the cross bar 53F in place with the flattened slightly angled end fixed to the frame with 1 x ABM screw.
The other end will be unattached for now.
Pic 2: Press-fit the brake elbow 53C into the side of the fitting 53A. (Marked with a small ‘L’)
Pic 3: Press-fit the brake elbow 53C into the side of the fitting 53B. (Marked with a small ‘R’)
Pic 4: Fit the left assembly to the frame as shown and fix with 1 x AM screw.
Pic 5: Fit the right assembly to the frame as shown and fix with 1 x AM screw.
Pic 6: Retrieve the main assembly and carefully place it upside down.
Fit the brake union 53D to the hole in the centre of the floor between the rear wheel arches as indicated.
Pic 7: From the other side, fix the union using 1 x AP screw through the central hole in front of the parcel shelf.
Pic 8: Cut the tube 53E into 2 x 50mm lengths and 2 x 60mm lengths.
Pic 9: Fit the 2 x 60mm tubes into the rear-facing holes in the pipe connectors as shown.
Pic 10: Fit the 2 x 50mm tubes into the upward-facing holes in the pipe connectors as shown.
#4 Posted : 06 February 2026 10:08:49
STAGE 54:
Prop shaft.
Pic 1: Locate the prop shaft parts 54C and 54D.
Pic 2: Press-fit the parts together as shown.
Pic 3: Fit the universal joint 54B in place as shown.
The UJ has two longer arms. These fit here.
Fix with 2 x AP screws.
Pic 4: Fit the other part of the universal joint 54A in place on the shorter arms of 54B and fix with 2 x AP screws.
Pic 5: Retrieve the main assembly and from above, remove the 3 x screws indicated that are holding the exhaust in place.
Keep the screws safely to one side as they will be used to re-fit the exhaust later.
Pic 6: Turn the model over and remove the exhaust.
Pic 7: Slide the prop shaft into place and connect it to the UJ at the rear of the transmission as shown.
Fix one side using 1 x AP screw.
Pic 8: Rotate the prop shaft and fix the other side of the UJ with another AP screw.
Pic 9: Re-fit the exhaust using the 3 x removed screws.
Store your model safely.
#5 Posted : 07 February 2026 12:14:43
STAGE 55:
Rear axle housing 1.
Pic 1: Fit the pump hose connector 55A in place to the inside pin of the cover 55B as shown.
Pic 2: Fit the cover to the axle 55A where indicated.
Pic 3: Fix from the other side with 2 x AM screws.
Pic 4: Fit the pump 55D to the pump mount 55G as shown.
It will only fit one way.
Pic 5: Fit the inner pump pulley 55F over the shaft on the pump mount as shown.
The pulley part 55F has a small notch in it.
Pic 6: Fit the other pulley half 55E in place and fix with 1 x DM screw.
Pic 7: Store the parts safely for now.
#6 Posted : 08 February 2026 13:00:26
STAGE 56:
Rear axle housing 2.
Pic 1: Fit the differential housing 56B to the rear axle 56A as shown.
Pic 2: Fix from behind using 2 x AM screws.
Pic 3: Fit the pump assembly from stage 55 and fix with 2 x AP screws.
Pic 4: Fit the hose 56D to the connector on the pump as shown.
Pic 5: Retrieve the assembly from stage 55 and fit the stabiliser bar 56C in place.
Pic 6: Store the parts safely.
This page was generated in 0.058 seconds.
