Issue 39
Picture 1 shows the parts for this issue. Fit the differential casing (39C) into the two holes in the centre part of the upper differential housing (39A), picture 2. Secure it in place using 2 x “I” screws, picture 3.
Insert the small mounting post on the driveshaft yoke (39D) onto the hole as shown in picture 4. Secure it using an “I” screw, picture 5.
Retrieve the assembly from issue 38 and place the upper differential housing over the lower housing, picture 6. Secure the two assemblies using 4 x F type screws, picture 7.
Fit one of the ends of the driveshaft (39B) onto the driveshaft yoke, picture 8.
Issue 40
Picture 1 shows the parts for this issue. Fit the rear shock absorber piston (40A) into the hole in the left rear shock absorber bracket (40B), picture 2.
Retrieve the assemblies from issues 37 and 39, placing the rear leaf spring in place, noting which way around it goes, picture 3. Place the shock absorber bracket over the leaf spring, matching the hole in the differential housing and secure the parts in place using an F type screw, picture 4.
Turn the assembly over and place the two “U” bolts from issue 38 either side of the leaf spring, picture 5. Turn the assembly over once more and secure the “U” bolts in place using 4 x D screws, picture 6.
Finally, fit the left rear brake plate (40C) onto the axle and secure it using 2 x H screws, picture 7.
Picture 8 shows the assembly complete for this issue.
Issue 41
Picture 1 shows the parts for this issue. Begin by fitting the first of the rear leaf spring shackles (41B) onto the shorter end of the right rear leaf spring (41A). Secure the shackle in place using a J screw as shown in picture 2.
Fit the second shackle to the other end in the same way, picture 3.
Picture 4 shows the assembly complete for this issue.
Issue 42
Picture 1 shows the parts for this issue. Fit the rear shock absorber piston (42A) into the hole in the right rear shock absorber bracket (42B), picture 2.
Retrieve the assemblies from issues 40 and 41, placing the rear leaf spring in place, noting which way around it goes, picture 3. Place the shock absorber bracket over the leaf spring, matching the hole in the differential housing and secure the parts in place using an F type screw, picture 4.
Turn the assembly over and place the two “U” bolts (42E) either side of the leaf spring, picture 5. Turn the assembly over once more and secure the “U” bolts in place using 4 x D screws, picture 6.
Fit the left rear brake plate (42C) onto the axle and secure it using 2 x H screws, picture 7.
Finally, fit the left and right brake drums, these just push into place, picture 8.
Picture 9 shows the assembly complete for this issue.
Issue 43
Picture 1 shows the parts for this issue. Insert the pins on the inside of the right rear wheel hub (43C) into the holes in the right rear wheel centre (43B), picture 2.
Fit the centre assembly into the three holes in the right rear wheel rim (43A), picture 3, and secure it in place using 3 x C screws, picture 4.
Issue 44
Picture 1 shows the parts for this issue. Press the right rear wheel rim from the previous issue, into the centre of the right rear tyre, picture 2. To make it easier to fit, warm the tyre in some hot water first.
To finish, fit the edge of the right rear tyre onto the rim, picture 3.
