Peugeot 205 Dakar Turbo Official Build STAGES 57 - 62 Options
#1 Posted : 11 February 2026 10:11:21
STAGE 57A:
Driver’s seat and harness.
Pic 1: Retrieve the floor and seat from the previous stage and fit the strap through the seat base.
Pic 2: Different view.
Pic 3: Fit the seat base 57A in place as shown with the longer tabs to the front and fix with 2 x XP screws in each side.
Pic 4: Fix the seat to the floor with 2 x AP screws.
Pic 5: Repeat on the other side.
#2 Posted : 11 February 2026 10:14:30
STAGE 57B:
Pic 6: Cut one end of the strap 57C to the shape as shown.
Pic 7: Carefully burn the end to seal it.
NOTE: An easier and safer way is to dip the end of the strap in a tiny dot of cyano glue and allow it to dry before cutting the shape.
Pic 8: Pass the strap through the bracket 57B (smaller bracket) as shown and stick a piece of double sided tape to the large end of the strap.
Pic 9: Peel the backing from the tape and fold it over the bracket.
Pic 10: Fit a catch 57D to the narrow end of the strap and using a piece of tape, fold it over in the same way.
Make another strap in the same way so you have two sets the same.
Pic 11: Using parts 57D, 57F, 57H and 57K, make two more sets of straps using the same method.
Pic 12: Straps assembled.
#3 Posted : 11 February 2026 10:17:42
STAGE 57C:
Pic 13: Lay a long strap 57G face down so the ‘Sabelt’ name is underneath and fit a large bracket 57E in place as shown.
The ‘S’ in Sabelt must be nearest to the bracket or the name will be upside down when finished.
Stick a piece of tape 57K as shown.
Pic 14: Fold the end of the strap over as with the other belts.
Pic 15: Retrieve strap 57F and pass the end of the new strap through the bracket 57H where indicated.
Pic 16: Again using the tape method, fold the end of the strap over and fix it in place.
Pic 17: Completed strap.
Note the direction of the name.
Pic 18: Make another set the same.
Pic 19: Fit one of the straps 57C through the side of the seat.
Pic 20: Fit the bracket to the floor and fix from underneath with 1 x AP screw.
#4 Posted : 11 February 2026 10:20:26
STAGE 57D:
Pic 21: Repeat with the other strap on the other side.
Pic 22: Fit the two long straps through the upper holes in the seat back.
It will be far easier to fit them from behind.
Pic 23: Locate the strap lock back 57J and fit the ends of the three lower straps in place as shown.
This VERY fiddly so be patient.
Pic 24: Fit the two upper straps in the same way.
Pic 25: Press-fit the front lock 57I into the central hole to fix everything together.
#5 Posted : 12 February 2026 14:22:35
STAGE 58:
Co-driver’s seat.
Pic 1: Cut the end of the strap 58C to the shape shown.
The printed instructions then tell you to carefully burn the ends of the strap to seal the fabric.
A far easier and safer alternative is to carefully dip the end of the strap in a tiny dot of Cyano adhesive and then let it dry, before cutting the shape.
This suggestion is entirely at the builder’s discretion.
Pic 2: Stick a piece of self-adhesive tape 58E to the strap as shown and then fit the buckle 58D.
Pic 3: Peel the backing from the tape and then fold the strap parts over as shown.
Pic 4: Slide the bracket58B onto the strap and fix a piece of tape 58E in place at the end of the strap.
Pic 5: Peel the backing from the tape and then fold the strap over as shown.
Pic 6: Retrieve the floor assembly 54A and fit the strap bracket as shown.
Fix from underneath with 1 x AP screw.
Pic 7: Store the parts safely for now.
#6 Posted : 14 February 2026 12:55:29
STAGE 59A:
Co-driver’s seat and harness.
Pic 2: Fit the seat base 59A in place as shown with the angled end to the rear and fix with 2 x XP screws in each side.
Pic 3: Fix the seat to the floor with 2 x AP screws.
Pic 4: Repeat on the other side.
Pic 5: Cut one end of the strap 59C to the shape as shown.
Make two sets
#7 Posted : 14 February 2026 12:57:55
STAGE 59B:
Pic 6: Pass the strap through the bracket 59B (smaller bracket) as shown and stick a piece of double sided tape to the large end of the strap.
Pic 7: Peel the backing from the tape and fold it over the bracket.
Pic 8: Fit a catch 59D to the narrow end of the strap and using a piece of tape, fold it over in the same way.
Pic 9: Make the other strap in the same way so you have two sets the same.
Pic 10: Using parts 59D, 59G, 59H and 59K, make two more sets of straps using the same method.
Pic 11: Straps assembled.
Pic 12: Lay a long strap 59F face down so the ‘Sabelt’ name is underneath and fit a large bracket 59E in place as shown.
Stick a piece of tape 59K as shown.
Pic 13: Fold the end of the strap over as with the other belts.
#8 Posted : 14 February 2026 13:01:04
STAGE 59C:
Pic 14: Retrieve strap 59G and pass the end of the new strap through the bracket 59H where indicated.
Pic 15: Completed straps.
Pic 16: Fit one of the straps 59C through the side of the seat.
Pic 17: Repeat with the other strap on the other side.
Pic 18: Fit the two long straps through the upper holes in the seat back.
Pic 19: Locate the strap lock back 59J and fit the ends of the three lower straps in place as shown.
Pic 20: Fit the two upper straps in the same way.
Press-fit the front lock 59I into the central hole to fix everything together.
#9 Posted : 15 February 2026 11:32:18
STAGE 60:
Inner fuel tank.
Pic 1: Fit the fuel line cover 60C to the tank 60A as shown and fix from the inside with 2 x KP screws.
Pic 2: Fit the fuel tank cap 60B in place and fix with 1 x AP screw from underneath.
Pic 3: Store the parts safely for now.
#10 Posted : 17 February 2026 11:26:46
STAGE 61:
Inner fuel tank 2.
Pic 1: Fit the tank protector 60D from the previous stage to the tank cover 61A as shown.
It will only fit one way.
Pic 2: Retrieve the tank 60A and fit the assembly as shown.
Fix from underneath with 2 x AP screws.
Pic 3: Fit the 4 x handles 61B as shown and fix with 2 x KP screws in each.
Pic 4: Fit the 2 x brackets 61C as shown and fix from behind with 1 x AP screw in each.
Pic 5: Retrieve the floor assembly and fit the tank support 61D in place behind the battery.
Fix from below with 3 x AP screws.
Pic 6: Fit the other tank support 61E on the other side.
Pic 7: Store the parts safely.
#11 Posted : 18 February 2026 13:00:58
STAGE 62A:
Fuel system controls
Pic 1: Locate the parts for the control box legs – 3 x 62D and 3 x 62E.
Press-fit the parts together as shown.
Pic 2: Press-fit the legs into the underside of the control box 62A.
Pic 3: Fit the buckle 62C over the strap 62B and stick a self-adhesive pad 62S on one end.
Pic 4: Peel the backing from the pad and fold the strap over the buckle as shown.
Pic 5: Stick another pad 62S on the other end of the strap.
Pic 6: Retrieve the fuel tank and press-fit the buckle in place as shown.
Make sure the buckle angles slightly outwards, toward the silver cap.
Pic 7: Press-fit the three legs on the control box assembly 62A into the locating holes on the top of the tank.
#12 Posted : 18 February 2026 13:03:51
STAGE 62B:
Pic 8: Pull the strap over the control box and pass it through the slot in the tank.
Stick the end of the strap in place under the tank.
Pic 9: Fit the two pumps 62H and 62I into the reservoir 62F.
Pic 10: Turn the assembly over and fit the back panel 62G.
Pic 11: Fit the connectors 62J and 62K to the reservoir in the positions indicated.
Pic 12: Press-fit the two legs on the reservoir into the slots on the top end of the tank in the position indicated.
Pic 13: Fit the tube 62R to the control box where shown.
Pass the tube under the reservoir.
Pic 14: Cut the long tube 62Q into the four lengths shown.
Pic 15: Fit the 70mm and 75mm tubes to the pumps in the order shown.
#13 Posted : 18 February 2026 13:06:05
STAGE 62C:
Pic 16: Fit the 50mm and 60mm tubes to the connectors in the order shown.
Pic 17: Assemble the fuel pump handle parts 62M and 62N as shown.
Pic 18: Fit the handle in place behind the co-driver’s seat.
Pic 19: Press-fit the large bracket 62L into the lower front of the tank.
Pic 20: Press-fit the handle 62P in place as shown.
Pic 21: Fit the battery cover 62O in place where indicated.
Pic 22: Secure from the other side with 3 x AP screws.
This page was generated in 0.387 seconds.
