 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,816 Points: 17,600 Location: ipswich
STAGE 45:
Remote control.
Pic 1: The rubber keypad 45C will fit inside the front panel 45B.
Pic 2: Parts assembled.
Pic 3: Fit the circuit board 45E inside the assembly as shown. It will only fit one way.
Pic 4: Clip the back cover 45A in place. The battery holder 45D will fit in the slot indicated.
Pic 5: Shows the functions of all the controls.
You can now add batteries to the model and the remote control to test the electronics.
To avoid posting 13 different copies of the printed instruction images, refer to the supplied booklet pages and keep the magazine for future reference.
Store your model and remote control safely after removing the batteries.roymattblack attached the following image(s):
STAGE 46A:
Steering box and wiring.
Pic 1: Locate the steering shaft parts 46B and 46E. They will fit together.
Pic 2: Assemble the parts and fix with 2 x AM screws.
Pic 3: Fit the universal joint 46G in the end of the assembly and fix with 2 x IM screws.
Pic 4: Fit the long shaft 46F as shown and fix with 2 x IM screws.
Pic 5: Fit another universal joint 46G in the open end of the assembly and fix with 2 x IM screws.
Pic 6: Locate the steering box parts 46A, 46D and 46H.
They will fit together in the order shown.roymattblack attached the following image(s):
STAGE 46B:
Pic 7: Fix the parts together with 1 x AM screw.
Pic 8: Fit the shaft assembly into the steering box as shown.
Pic 9: Fit the cover 46C and fix with 2 x IM screws.
Pic 10: Retrieve the main car assembly and ‘wiggle’ the steering box in place behind the shock absorber. The steering box is outlined in yellow for clarity.
Pic 11: Turn the front wheels so the screw shaft on the steering rack is accessible. Fit the steering arm from the steering box over it.
Pic 12: Fix the parts together using 1 x GM screw.
Pic 13: Move the steering box so it sits on the side chassis frame and fix with 2 x AM screws.
STAGE 46C:
Pic 14: Fit the two connectors 46J and 46K to the oil cooler 46L in the positions shown.
Pic 15: Press-fit the cooler front 46M in place.
Pic 16: Connect the oil cooler to the two hoses coming from the engine. The hoses are highlighted in yellow for clarity.
Pic 17: Fit the cooler down the inside of the chassis rail. The two pins on the bottom will locate in two fixing tabs.
Pic 18: Press-fit the crankcase rod (dip stick) into the locating hole at the bottom of the engine.
Pic 19: Fit the oil hose 46O to the pin on the steering pump and the other end to the pin on the manifold. The hose is highlighted in yellow for clarity.
Pic 20: Connect the cable 46P to the pin on the throttle assembly as shown. The other end is free for now.roymattblack attached the following image(s):
STAGE 46D:
Pic 21: Connect the sensor pipe 46N to the pin on the sensor where indicated. Pass the pipe through the retaining clip as shown. The other end is free for now.
WIRING:
Pic 22: Retrieve the main assembly and carefully gather together the wires I, M, N, O, P, Q and R. Run them towards the rear of the car as shown and tape them down using pieces of tape 22D.
Pic 23: Gather together the wires A, B, C, D, E, F, G and H. Run them neatly towards the front of the car and tape them down using pieces of 22D tape as shown.
Pic 24: Gather together the three wires on the far rear side of the chassis and tape them down in the same way.
Pic 25: Carefully unplug all the wiring extensions on the front cables and store them safely in a labelled bag for future use.
Pic 26: Carefully unplug all the wiring extensions on the rear cables and store them safely in a labelled bag for future use.
Store everything safely for now.roymattblack attached the following image(s):
STAGE 47:
Front left wheel arch.
Pic 1: Locate the arch parts 47A and 47C.
Pic 2: Fit the parts together as shown and fix with 1 x IP screw.
Pic 3: Locate the arch part 47B.
Pic 4: Fit it to the front of the assembly and fix with 1 x IP screw.
Pic 5: Retrieve the main assembly and move all of the front wires out of the way of where the wheel arch will fit.
Pic 6: Fit the arch as shown and fix with 3 x BM screws.
Store the model safely.roymattblack attached the following image(s):
STAGE 48:
Front right wheel arch.
Pic 1: Locate the arch parts 48A and 48C.
Pic 3: Locate the arch part 48B. Fit it to the front of the assembly and fix with 1 x IP screw.
Pic 4: Retrieve the main assembly and fit the arch as shown. Fix with 3 x BM screws.
STAGE 49:
Left engine bay panel.
Pic 1: Fit the screen washer reservoir 49B to the inner wing panel 49A where shown and fix from behind with 1 x CP screw.
Pic 2: Retrieve the main assembly and fit the wing panel in place on the left front as shown. Make sure the spring assembly locates in the top cap on the wing panel. Fix through the wing into the spring cap using 1 x EM screw. Fix the lower edge with 3 x BM screws where shown.
Pic 3: Fix the outer arch to the inner wing with 2 x IP screws.
Pic 4: Carefully turn the model over and fix the parts where shown using 1 x BM screw and 1 x AM screw.
STAGE 50A:
Battery, fuse box and reservoirs.
Pic 1: Fit the blue battery lead 50B to the pin on the inner front sidewall.
Pic 2: Locate the reservoir parts 50P, 50Q and 50R. They will press-fit together in the order shown.
Pic 3: Reservoir assembled.
Pic 4: Fit the pipe 50S to the reservoir.
Pic 5: Connect the end of the pipe to the pin on the pump as indicated.
Pic 6: Fix the reservoir to the sidewall using 1 x IM screw.
STAGE 50B:
Pic 7: Fit the battery parts 50A and 50B together and fix with 2 x AP screws.
Pic 8: Fit the battery to the front of the main assembly as shown and fix from underneath with 2 x AP screws.
Pic 9: Press-fit the terminal 50C to the battery and connect the wire 23D that comes from the starter motor.
Pic 10: Press-fit the terminal 50D to the battery and connect the blue wire 50E.
Pic 11: Fit the two supports 50H and 50G to the battery clamp 50F in the positions shown.
Pic 12: Fit the clamp over the battery, locating the rods in the holes in the main frame.
Pic 13: Locate the fuse box parts 50J, 50K and 50L.
STAGE 50 C:
Pic 14: Press-fit the parts together as shown.
Pic 15: Fit the fuse box in place just behind the battery and fix from below with 1 x AP screw.
Pic 16: Fit the coolant reservoir parts 50L and 50M together and fix with 1 x KP screw.
Pic 17: Fit the connector 50N and then attach the overflow pipe 50O as shown.
Pic 18: Press-fit the reservoir to the locating holes in the sidewall as shown and feed the pipe behind the battery clamp rod.
Store the model safely for now.roymattblack attached the following image(s):
