Red Bull RB19 Official build. Stages 45 - 50 Options
#1 Posted : 14 February 2026 13:24:38
STAGE 45:
Rear left suspension 2.
Pic 1: Locate the hub parts 59C and 59D.
They will fit together as indicated.
Pic 2: Parts assembled.
Pic 3: Fit the assembly to the back plate 45A.
Pic 4: From the other side, fix with 2 x ‘B’ screws.
Pic 5: Fit the arm support 45B to the plate as shown and fix with 2 x ‘I’ screws from the other side.
Pic 6: Retrieve the assembly from the previous stage and fit the new assembly in place as shown.
It will only fit one way.
Pic 7: Fix from the other side with 2 x ‘A’ screws.
Store the assembly safely.
#2 Posted : 15 February 2026 11:55:53
STAGE 46:
Rear left suspension 3.
Pic 1: Locate the main hub assembly and fit the arm 46A through the upper slot in the backplate as shown.
Fix on the inside using 1 x ‘B’ screw.
Pic 2: Turn the assembly over and fit the other arm 46B through the other slot in the position shown.
Fix from the inside with 1 x ‘B’ screw.
#3 Posted : 17 February 2026 10:47:37
STAGE 47:
Rear left suspension 4.
Pic 1: Retrieve the assembly from the previous stage and fit the arm 47A through the slot in the top of the hub in the direction shown.
Fix from the inside edge of the hub with 1 x ‘S’ screw.
Pic 2: Press-fit the brake deflector 47B into the backplate as shown.
Pic 3: Fix the parts together with 1 x ‘R’ screw where indicated.
NOTE: The printed instructions show the screw being fitted in the wrong place.
#4 Posted : 18 February 2026 11:37:04
STAGE 48:
Rear left suspension 5.
Pic 1: Retrieve the assembly from the previous stage and locate the brake outer cover 48A.
This part will push-fit into the locating holes indicated.
Store the assembly and unused part safely for now.
#5 Posted : 19 February 2026 11:32:28
STAGE 49:
Rear left suspension 6.
Pic 1: Locate the disc rear 49A and the vent strip 49C.
Pic 2: Fit the hooked end of the strip into the slot the disc.
Pic 3: Wrap the strip all the way round the disc and fit the end into the slot, then bend it over to fix it in place.
Pic 4: Press the front of the disc 49B in place.
Pic 5: Retrieve the assembly from the previous stage and fit the disc in place as shown.
Pic 6: Fit the outer hub 48B saved from the previous stage.
Store safely for now.
#6 Posted : 20 February 2026 11:21:14
STAGE 50:
Rear left suspension 7.
Pic 1: Retrieve the assembly from the previous stage and press-fit the brake caliper 50A in place as shown.
Pic 2: Store everything safely for now.
This page was generated in 0.181 seconds.
