1989 Batmobile Official build STAGES 15 - 20 Options
#1 Posted : 26 February 2026 15:47:09
STAGE 15:
Left rear swing arm.
Pic 1: Locate the arm 15-2, bracket, 15-3 and screw ‘F’.
The parts fit together in the order shown.
Pic 2: Parts assembled.
Pic 3: Locate the arm 15-1, 2 x brackets, 15-3 and 2 x screws ‘F’.
Pic 4: Parts assembled.
Pic 5: Retrieve the assembly from stage 14 and fit the arm 15-2 as shown.
Fix using 1 x ‘G’ screw.
Pic 6: Fit the other arm 15-1 to the other end of the hub, between the springs and fix with 1 x ‘G’ screw.
Pic 7: Shows the arm fitted (highlighted in yellow) from a different angle for clarity.
Store the assembly safely.
#2 Posted : 27 February 2026 09:54:31
STAGE 16:
Rear frame.
Pic 1: Fit the 2 x suspension bases 16-2 to the top of the frame 16-1 as shown and fix with 2 x ‘D’ screws in each.
Pic 2: Retrieve the hub assembly from the previous stage and fit it against the frame as shown.
The 4 x flexible brackets on the ends of the swing arms locate in the 4 x recesses on the frame.
This is quite fiddly so it is suggested you fix them as follows:
Pic 3: Position the arm 14-A first, ignoring the other three fixings for now.
Fix with 1 x ‘G’ screw.
Then position the end of arm 15-2, and fix with 1 x ‘G’ screw.
Pic 4: Position the ends of the ‘A’ shaped arm 15-1 in the locating holes and fix with 2 x ‘G’ screws.
Pic 5: From the other side, fix the tops of the dampers using 4 x ‘R’ screws.
#3 Posted : 28 February 2026 13:01:13
STAGE 17:
Right rear suspension.
NOTE: Steps 1 and 2 are missing from the printed instructions which only describe step 3 (pic 4 below) but they are detailed here.
Pic 1: Locate the lower arm 17-3 and bracket 17-4.
You will also need 1 x screw ‘F’.
Pic 3: Fit the assembly to the bottom of 17-2, between the silver forks as shown.
Fix with 1 x ‘F’ screw.
Pic 4: Fit the hub 17-1 to the lower arm just fitted to the assembly and fix from below with 1 x ‘G’ screw.
Store safely for now.
#4 Posted : 01 March 2026 11:54:58
STAGE 18:
Right rear brake.
Pic 1: Retrieve the assembly from the previous stage and fit the caliper 18-6 as shown.
Fix from behind with 1 x ‘A’ screw.
Pic 2: Press-fit the backing plate 18-4 into place.
It will only fit one way.
Pic 3: Locate the disc parts 18-1 and 18-2.
They will fit together one on top of the other.
Pic 4: Wit the parts together, peel the backing from the steel disc face 18-3 and stick it in place as shown.
Pic 5: Fit the disc centre 18-5 in place and fix from behind with 2 x ‘I’ screws.
Pic 6: Store everything safely for now.
#5 Posted : 02 March 2026 11:26:10
STAGE 19A:
Right rear swing arms.
Pic 1: Fix the arm 19-2 and bracket 19-3 together using 1 x ‘F’ screw.
Pic 3: Retrieve the hub assembly 18-A and fit the arm 19-2 as shown.
Pic 4: Assemble the lower swing arm 19-1 and 2 x brackets 19-3 fixing them from the outside with 2 x ‘F’ screws.
Pic 5: Parts assembled.
#6 Posted : 02 March 2026 11:28:44
STAGE 19B:
Pic 6: Fit the assembly between the springs on the hub as shown.
Pic 7: On the other side of the springs, fix the arm in place on the hub with 1 x ‘G’ screw.
Pic 8: Retrieve the rear frame assembly and fit the hub unit in place as shown.
Pic 9: First, attach the central hub arm 19-A in place as shown and fix from the other side with 1 x ‘G’ screw.
Pic 10: Fit the outer arm 19-2 in place and fix with 1 x ‘G’ screw.
Pic 11: Fit the two end brackets on the lower arm assembly 19B and fix using 2 x ‘G’ screws as shown.
Pic 12: Fix the upper ends of the shock absorbers using 4 x ‘R’ screws.
#7 Posted : 03 March 2026 16:43:52
STAGE 20:
Left machine gun.
Pic 1: Fit the piston 20-7 into the sleeve 20-8 and then attach the parts to the support bracket 20-6 using 1 x ‘L’ screw.
Pic 2: Fit the cover 20-9 in place.
Pic 3: Fit the top cover 20-5 into the edge of the gun housing 20-2 as shown.
Pic 4: Fit the spring 20-4 onto the firing pin 20-3.
Pic 5: Fit the assembly inside the gun body 20-2 as shown.
Pic 6: Fit the assembly from step 1 into the gun as shown.
Pic 7: Fit the other half of the gun 20-1 in place and fix with 1 x ‘H’ screw.
Pic 8: Store safely for now.
This page was generated in 0.240 seconds.
