Iron Spiderman Official Build Issues 57 - 62 Options
#1 Posted : 02 March 2026 20:58:19
Issue 57 Part 1
The Shoulder connectors and Right Leg
Take the left shoulder connector and place 4 x M3 nuts into the holes as shown in picture 2. Place the left connector cover over the nuts and into the shoulder connector and secure it in place using an E type screw, picture 3. Now take the right shoulder connector and place the last four M3 nuts as before, picture 4, then cover it with the right connector cover, securing it using an E type screw, picture 5.
Retrieve the torso assembled in issue 56 and fit the left shoulder connector into the shoulder socket, securing it in place using 4 x type G screws, picture 6. Do the same on the opposite side with the right shoulder cover, picture 7.
Next, we make the cardboard stand for the torso, picture 8. Fold the side panels as shown in picture 9, with the four tabs facing inwards, then fold the side in over the tabs, picture 10. Finally, push the tabs on the top inwards as illustrated in picture 11.
Picture 12 shows the assembly complete for part 1 of this issue.
#2 Posted : 02 March 2026 21:00:54
Issue 57 Part 2
Right Leg
Plug one of the ends of the cable into the coil connector, picture 13. Place the coil base into the sole of the right foot, picture 14, then place the coil connector into the base, picture 15. Position the cover so the slot goes over the cable, then secure it in place using 2 x type F screws, picture 16.
Fit the right heel gold trim onto the heel and fix the two parts together with 2 x type E screws, picture 17.
Finally fit the heel on the back of the sole and secure it in place using two more type E screws, picture 18.
Picture 19 shows the assembly complete for part 2 of this issue.
#3 Posted : 04 March 2026 19:59:36
Issue 58
The Right Leg
Retrieve the right foot assembly from issue 57 and fit the foot mount inside, taking care not to trap the cable. Secure it in place with 2 x type P screws using the M4 allen key, picture 2.
Position the right foot post over the foot mount making sure the arrow, as shown in picture 3, is pointing upwards.
Fit the inner structure of the foot on the side of the post, picture 4. Fasten the foot structure with a type J screw, also picture 4. Finish securing the structure using two M3 hexagonal anti slip nuts, picture 5 and Type R screws on the other side, picture 6.
Finally, reinforce the joint by attaching a type J screw through the sole as shown in picture 7.
Picture 8 shows the assembly complete for part 1 of this issue.
#4 Posted : 06 March 2026 10:03:14
Issue 59
The Right Leg
Retrieve the right foot assembly from issue 58 and fit the right leg frame as shown in picture 2. Prepare a type R screw by fixing on a serrated washer, picture 3. Secure the frame to the foot by pushing the screw through the hole with an M3 nut on the opposite side of the hole, pictures 4 and 5.
Now fit the right knee attachment making sure the arrow faces upwards, picture 6. Secure this in place using 2 x type Q screws and 2 x M4 nuts, pictures 7 and 8.
At the base of the right inner foot cover, fit the gold detail as shown in picture 9. Fix the right leg inner cover onto the frame, picture 10, and secure in place using 4 x type E screws as illustrated in picture 11.
Finally, secure the top part of the leg cover using a type E screw, picture 12.
Picture 13 shows the assembly complete for this issue.
#5 Posted : 09 March 2026 20:02:49
Issue 60
The Right Leg
On the inside of the right leg outer cover, position and fit the gold detail, securing it in place with a type E screw, picture 2. Push the right foot outer frame into the outer cover and secure it using 3 x type E screws, picture 3.
Retrieve the right leg assembly and fit it into the outer frame, picture 4. Make sure you do not trap the cable. Holding the parts together, place a J screw into the foot as illustrated in picture 5. Fit two more type J screws as shown in picture 6. Fit another type J screw into the sole, picture 7.
On the back of the leg, push fit the lower calf cover, pictures 8 and 9. Press the right foot top cover into the correct position, it is best to fit it starting from the toe. Secure in place using a type F screw, picture 10, followed by a type E screw as shown in picture 11.
Finally, press the toe cap into place, pushing in the centre to secure it in position, picture 12.
#6 Posted : 14 March 2026 16:58:30
Issue 61 Part 1
The Right Leg
Push the leg post into the knee attachment, making sure the arrow is pointing upwards as illustrated in picture 2. Secure it in place using 2 x type Q screws and 2 x M4 nuts, pictures 3 and 4.
On the outside of the right calf frame, position and fit the calf gold detail, securing it using 2 x type E screws, picture 5. Place the blue calf plate above the gold detail and fix it in place using a type E screws, picture 6. Now fix the next gold detail in place, picture 7. Turn the assembly over and place 2 x type F screws to secure it in place, picture 8.
Plug the right leg LED cable into the connector in the right leg circuit board, picture 9. The fit the circuit board to the recess in the side of the shin frame, picture 10, securing it with a type E screw. Feed the cable through the part, picture 11.
That completes part 1 of this issue.
#7 Posted : 14 March 2026 17:09:38
Issue 61 Part 2
The Right Leg
Position the right LED cover inside the blue shin plate, picture 12. Place the assembly over the right shin frame and secure using a type E screw, picture 13. Next, fit the upper gold detail, securing it from the inside with 2 x type F screws, pictures 14 and 15.
Take the calf assembly and fit it to the right leg, securing it using 2 x type G screws, pictures 16 and 17. Now attach the shin piece to the leg, securing it in place using 2 x type G screws, pictures 18 and 19. Finish the assembly with two type E screws at the rear of the leg, picture 20.
#8 Posted : 15 March 2026 12:30:14
Issue 62
The Right Leg
Picture 1 show the parts for this issue
Retrieve the right leg assembly from the previous issue and fit the right shin cover, picture 2.
On the outside of the leg, fit the two gold details and secure both in place using 2 x type E screws for each one, picture 3. Repeat the step for the gold details on the inside of the leg, picture 4.
Now fit the inner back cover securing it using a type S screw, picture 5. Do the same with the outer back cover, picture 6.
On the inner pins of the central back cover, place a magnet and tighten 2 x type I screws to hold the magnets in position, picture 7. Note: DO NOT over tighten as you will damage the magnets. Now fit the central cover in place on the back of the leg assembly, picture 8.
Picture 9 shows the assembly complete for this issue.
This page was generated in 0.084 seconds.
