Red Bull RB19 Official build. Stages 51 - 56 Options
#1 Posted : 12 March 2026 12:30:56
STAGE 51:
Rear left suspension 8.
Pic 1: Retrieve the assembly from the previous stage and locate the outer disc 51B.
Pic 2: Peel the backing from the disc 51B and press it into place on the disc 49B as shown.
Pic 3: Store all parts safely for now.
#2 Posted : 13 March 2026 15:43:09
STAGE 52:
Rear left wheel 1.
Pic 1: Retrieve the wheel rim 51A from the previous stage and locate the tyre 52A.
Pic 2: Press the rim into the tyre making sure the red outer rim is on the same side as the yellow markings on the tyre.
NOTE: You may find it easier if you soak the tyre in hot water for a few minutes and then dry it before fitting it to the rim.
Take care using hot water.
Pic 3: Store the parts safely for now.
#3 Posted : 16 March 2026 10:48:30
STAGE 53:
Rear left suspension.
Pic 1: Locate the rear wheel cover parts 53A and 53B.
They will fit with 53B inside 53A.
Pic 2: Fix the parts together as shown with 2 x ‘A’ screws.
Pic 3: Retrieve the suspension assembly from stage 51, the wheel from stage 52, the cover 53A, the bolt 53B and hub nut 50B.
Pic 4: Fit the wheel to the hub unit, place the cover in the centre and then fix the parts together with the hub nut and finally the long bolt.
This stage will not actually be done here.
All wheels will be fitted at the end of the build due to the extra weight and risk of damage.
#4 Posted : 17 March 2026 15:58:16
STAGE 54:
Rear right suspension 1.
Pic 1: Fix the bracket 54B to the fairing 54A with 1 x ‘A’ screw.
Pic 2: From the other side, fit the arm 54C as shown and fix from the other side with 1 x ‘Q’ screw.
Pic 3: Fit the arm 54D as shown and fix from the other side with 1 x ‘Q’ screw.
Store safely for now.
#5 Posted : 19 March 2026 10:55:20
STAGE 55:
Rear right suspension 2.
Pic 1: Fix the arm support 55B to the right steering knuckle 55A with 2 x ‘I’ screws from the other side as shown.
Pic 2: Fit the inner hub 55D into the support 55C as shown.
Pic 3: Fix the assembly to the knuckle with 2 x ‘B’ screws from the other side.
Pic 4: Retrieve the assembly from the previous stage and fix the knuckle in place with 2 x ‘A’ screws.
Pic 5: A different view of the assembly.
#6 Posted : 20 March 2026 13:18:12
STAGE 56:
Rear right suspension 3.
Pic 1: Retrieve the assembly from the previous stage and fit the arm 56A through the upper slot on the backplate, in the position shown.
Fix from above on the other side of the backplate with 1 x ‘B’ screw.
Pic 2: Fit the arm 56B in the remaining slot in the position shown.
Fix from below on the other side of the backplate with 1 x ‘B’ screw.
This page was generated in 0.180 seconds.
