Lamborghini Revuelto official build Stages 3 - 5 Options
#1 Posted : 29 March 2026 18:12:26
STAGE 3:
Brake disc and front wheel.
Pic 1: Disc 3A will fit onto disc 3b.
Peel the backing from 3A and stick it to the upper face of 3B.
Pic 2: Parts assembled.
Pic 3: From the other side, fit the disc centre 3C in place.
Pic 4: The parts are a very loose fit so it might be advisable to secure them for now with a piece of low tack masking tape.
Pic 5: Parts assembled, from the other side.
Pic 6: Locate the tyre 3D and the rim 3E.
Pic 7: Soak the tyre in hot water for about 30 seconds.
Be careful with hot water.
Pic 8: Remove the tyre from the water with tongs and dry it inside and out.
Pic 9: Press the rim 3E into the tyre paying attention to the tread pattern as shown.
The wide grooves go on the side of the rim face.
Pic 10: Store all parts safely for now.
#2 Posted : 01 April 2026 11:54:05
STAGE 4:
Driver’s seat.
Pic 1: Locate seat parts 4B and 4C.
Pic 2: Fit the parts together as shown.
Pic 3: Fix from behind with 4 x B screws.
Pic 4: Carefully fit the seat face 4A over the assembly making sure it tucks in correctly all over.
Pic 5: Fit the headrest parts 4D and 4E.
Pic 6: Fix from behind with 4 x B screws.
Pic 7: Fix the seat back 4F in place with 4 x B screws.
Pic 8: Fit the side panels 4H and 4G as shown.
Pic 9: Fix from underneath with 4 x B screws.
Pic 10: Store safely for now.
#3 Posted : 03 April 2026 13:24:43
STAGE 5:
Hood panel and steering wheel.
Pic 1: Retrieve the bonnet/hood panel 1A and lay it face side down.
The inner panel 5A will fit inside.
Pic 2: Fix the parts with 4 x C screws.
Pic 3: Locate the steering wheel parts 5B and 5C.
Pic 4: Fit the parts together as shown and fix from behind with 2 x D screws.
Pic 5: Store everything safely for now.
This page was generated in 0.186 seconds.
