 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,805 Points: 17,567 Location: ipswich
STAGE 21:
Left machine gun 2.
Pic 1: Press-fit the muzzle 21-3 onto the end of the barrel housing 21-4 as shown.
Optional detail: You can carefully fill in the recesses on the housing with a fine black Sharpie to enhance the look. This is at the builder’s discretion.
Pic 2: Retrieve the gun assembly from the previous stage and fit the barrel 21-2.
Pic 3: Fit the housing over the barrel as shown.
Pic 4: Press-fit the magazine 21-6 into the side of the gun body noting which way up it goes.
Pic 5: Lift the top cover.
Pic 6: Press-fit the bullet strip 21-5 in place as shown and then close the cover.
Pic 7: Store the assembly and unused part safely.
STAGE 22:
Left disc launcher.
Pic 1: Fit the bracket 22-2 and cover 22-1 together as shown and fix with 1 x ‘G’ screw.
Pic 2: Push-fit the disc holder 22-3 into place as shown.
Pic 3: Locate the disc parts 22-4 and 22-5. They will press-fit together.
Pic 4: Disc assembled.
Pic 5: Store the parts safely for now.
STAGE 23:
Disc and gun compartment.
Pic 1: Locate the disc parts 23-2 and 23-3. They will press-fit together.
Pic 2: Parts assembled.
Pic 3: Store everything safely for now.
STAGE 24:
Left front wing.
Pic 1: Position the wing 24-1 upside down and fit the gun compartment 23-1 in place as shown. Fix with 2 x A screws.
Pic 2: With the wing on its side as shown, fit the gun cover 24-2 in place and fix with 2 x A screws.
Pic 3: You can fit the machine gun here. It is attached with magnets. This is an optional fitting.
Pic 4: Alternatively you can fit the top cover 21-1 which is also held by magnets. Both of these optional parts will be kept safely until the end of the build.
STAGE 25:
Left disc compartment.
Pic 1: Assemble 2 x discs using parts 25-2 and 25-3 as before.
Pic 2: Retrieve the disc holder 22B (outlined in grey) and fit it into the left wing as shown. Fit the leading edge through the aperture first.
Pic 3: Fit the cover 25-1 in place and fix with 2 x A screws.
Pic 4: From the outside, clip the 4 x discs into the holder.
Pic 5: Fit the lower cover 23-4 (outlined in grey) in place. It is held with magnets.
STAGE 25:
Left headlight.
Pic 1: Retrieve the front left wing and fit the headlight lens 26-2 in place. It will only fit one way.
The following steps are not in the order in the printed magazine, to make assembly far easier.
Pic 2: Locate one of the ‘C’ wires and carefully make a right angle bend just behind the LED as shown.
Pic 3: Fit the LED into the left hole in the light holder 26-1 with the wires locating in the slot at the bottom. Push-fit the holder 26-4 (it is shorter than the other two) to keep the LED in place. The hollow area of the holder should be at the bottom.
Pic 4: Fit the other two ‘C’ LED’s in the same way, using the 2 x 26-3 holders.
Pic 5: Secure the assembly into the front wing using 1 x G screw.
Pic 6: Store the assembly safely for now.roymattblack attached the following image(s):
