Ferrari F1-2000 Official build Stages 1 - 2 Options
#1 Posted : 02 April 2026 16:08:35
STAGE 1A:
Front spoiler.
Pic 1: Locate the spoiler parts 1A and 1B.
They will press-fit together.
Pic 2: Parts assembled.
Pic 3: Locate the spoiler parts 1C and 1D.
Pic 4: Parts assembled.
Pic 5: Fit the end plate to the spoiler as shown and fix with 1 x NM screw.
Pic 6: Repeat on the other side with part 1G.
Pic 7: Fit the upper spoiler in place as shown.
The parts fit with pins/locating holes.
#2 Posted : 02 April 2026 17:24:48
STAGE 1B:
Pic 8: Fix at both ends with 1 x NP screw on each side.
Pic 9: Locate the lower flaps 1I and 1J.
They have a raised lip on one side which should be positioned upwards.
Pic 10: Press-fit the parts in place as shown.
Pic 11: Locate the upper fin 1H and press-fit it in place as shown.
Do the same on the other side with fin 1F.
Pic 12: Stick one of the pads 1L to the back of the flap adjuster 1K as shown.
Pic 13: Peel the backing paper off and stick the adjuster in place on the end of the spoiler.
The wider side of the adjuster should be towards the rear.
Repeat on the other side.
Pic 14: Store the assembly safely for now.
#3 Posted : 04 April 2026 12:00:59
STAGE 2:
Nose.
Pic 1: Locate the nose parts 2A and 2D.
Place 2A upside down.
Pic 2: Fit the parts together and fix with 3 x CM screws.
Pic 3: Locate the wing supports 2B and 2C.
They are actually identical.
Pic 4: Press-fit the supports in place on the nose turrets as shown, narrow ends to the rear.
Pic 5: Retrieve the wing assembly and fix it in place on the turrets with 4 x AJM screws.
Pic 6: Press-fit the front camera 2E in place where indicated.
This page was generated in 0.247 seconds.
