Issue 45
The Right Leg Rear Cover Save this part for future assembly steps.
Issue 46
The Right Leg Front Cover Save this part for future assembly steps.
That completes the assembly for this issue.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Issue 47
The Pelvis Front Cover Save this part for future assembly steps.
Issue 48
The Torso Front Cover Place the torso front cover (48A) onto the front pelvis cover from issue 47 and secure them using 4 x MP screws, pictures 2 and 3.
Issue 49
The Right Leg Outer Protection Save this part for future assembly steps.
Issue 50
The Right Leg Inner Protection Insert the internal frame (50A) into the right leg frame from the previous issue and secure them using 2 x LP screws, pictures 2 and 3.
Place the fastening straps (50B and 50C) inside the protection using 2 x SP screws for each one.
Note: please make sure you have the straps the right side up and the right orientation as illustrated in picture 4.
Picture 6 shows the assembly complete for this issue.
