 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
STAGE 75:
Right seat, battery, and rear left base.
Pic 1: Fit the battery base to the frame on the left of the car as shown. Fix from underneath with 2 x AP screws.
Pic 2: Press-fit the battery top 74D in place keeping the terminals to the rear as highlighted.
Pic 3: Retrieve wire 74E and cut into 1 x 100mm and 1 x 180mm pieces.
Pic 4: Connect them to the battery as shown.
Pic 5: Pass the wires through the rectangular hole next to the red switch wire in the black lower bulkhead.
Pic 6: Connect the 180mm wire to the 3rd pin on the alternator as shown.
Pic 7: With the model upside down, connect the 100mm wire to the pin on the angled rear bulkhead frame as shown.
Pic 8: Locate the free ends of the two other wires on the alternator.
Pic 9: With the model upside down, pass the wires down and connect them to the two pins on the rear body wall.
Pic 10: Retrieve the left rear base assembly 64A.
Pic 11: Fit the assembly in place on the car as shown, passing the red switch wire through the rectangular hole. This is a fiddly operation so be patient. Fix with 3 x AM screws.
Store the model and unused screws and seat parts safely for now.roymattblack attached the following image(s):
STAGE 76:
Left fuel reservoir, sill trim, seat side and right pump base.
Pic 1: There are three unconnected clear hoses on the left pump base. 1 x 90mm and 2 x 120mm.
Connect the 90mm hose (highlighted in yellow) to the pin next to the two black alternator wires on the red rear bulkhead.
Pic 2: Connect the 2 x 120mm hoses to the two pins on the bulkhead as shown.
Pic 3: Turn the model upside down and connect the two hoses 21D and 57C to the inner side of the tank base as shown.
Pic 4: Fit the air duct 65D in place as shown. This is very fiddly.
Pass the straighter end through the end panel in the pump base first and wiggle it into place. Then bend the air duct (it is quite flexible) to get it behind the hub plate so you can connect that end.
Pic 5: Retrieve the right pump base assembly and remove the side plate 67C. Keep the part and the screw to one side for now.
Pic 6: With the car upside down, remove the angled pipe coming from the front of the engine as indicated.
Pic 7: Unscrew the suspension arm 59A (highlighted in yellow) and move it aside. Do not lose the screw.
Pic 8: Fit the pump base in place as before and fix with 3 x AM screws.
Pic 9: Fit the straight end of the disconnected pipe into the hole in the side of the pump base and then reconnect the angled end to the engine.
Pic 10: Re-fit the suspension arm 59A to the bulkhead.
Store the model and unused parts safely for now.roymattblack attached the following image(s):
STAGE 77: Reservoir, door trim, gearbox parts.
Pic 1: Position the model so you can see clearly inside the right rear tank. Locate the fuel pipe attached to the upper rear red bulkhead and fit the free end onto the pin on the lower connector. The pipe is highlighted in yellow for clarity. Be patient as this is quite fiddly.
Pic 2: Locate the two black soft fabric hoses 69G and 67H. They will be inside the right rear tank. You need to feed them behind the rear of the engine as shown and connect the ends to the two holes in the housing.
Pic 3: Locate the free end of the silver fabric hose 43F and connect it to the hole in the top of the connector, next to the black hose as shown.
Pic 4: Fit the rear panel saved from stage 73 to the rear wall as shown and fix with 5 x AM screws.
Pic 5: Press-fit the seat saved from stage 74 in place on the frame as shown.
Pic 6: Fit the air duct saved from stage 69 as shown. Fit the straight end first and then bend the hose into position on the rear of the hub. This is not difficult as the hose is quite flexible.
Store the model and unused parts safely.roymattblack attached the following image(s):
STAGE 78:
Seat parts and safety belt.
Pic 1: Retrieve seat parts 75A and 75B and fit them together as shown.
Pic 2: Fix with 2 x AP screws from underneath.
Pic 3: Fit the centre tunnel cover 74B in place.
Pic 4: Fix from underneath with 2 x AP screws.
Pic 5: Slide the belt 75C through the slot indicated.
Pic 6: Fit the assembly into the car as shown.
Pic 7: Fix from underneath with 4 x AP screws.
Pic 8: Tie the seat belt to the central frame as shown.
Pic 9: Store the model and unused parts safely for now.
STAGE 79A:
Partitions and intake supports.
Pic 1: Retrieve the seat side part 76C and fit it in place as shown.
Pic 2: From underneath, fix it with 2 x AP screws.
Pic 3: Fit the reservoir body 76A in place and fix with 2 x AM screws.
Pic 4: From underneath, fix the part with 2 x AP screws.
Pic 5: Fit the sill trim 76B in place and fix with 2 x AKP screws.
Pic 6: Locate the gear shift parts 77E, 77F, 77G and 77H.
Pic 7: Press-fit the parts together as shown.
STAGE 79B:
Pic 8: Fit the assembly to the side of the cover 77A as shown. You might be advised to use adhesive here as the parts are not a tight fit. This is at the builder’s discretion.
Pic 9: Press-fit the switch 77D in place where indicated.
Pic 10: On the main assembly, pass all the wiring indicated through the rear firewall to exit the tank as shown.
Pic 11: Fit the 77A assembly in place and fix with 2 x AM screws.
Pic 12: From underneath, check the gear rod locates in the hole in the rear firewall – highlighted in yellow. Fix the cover with 2 x AP screws.
Pic 13: Fit the sill trim 77B in place and fix with 2 x AKP screws.
Pic 14: Press-fit the handle 77B in place on the sill trim.
Store the model and all unused parts safely.roymattblack attached the following image(s):
STAGE 80:
Dashboard and seat back fitting.
Pic 1: Retrieve the seat back parts 78A, 78B, 78C and 78D. Fit them together as shown.
Pic 2: Fix from behind with 6 x AKP screws.
Pic 3: Fit the assembly into the car and fix with 9 x QM screws.
Pic 4: From underneath, fix the seat base using 2 x AKP screws.
Pic 5: Fix the harness 78E to the seat back with 2 x KM screws.
Pic 6: With the model upside down, locate the two long hoses attacked to the brake master cylinder at the front. 1 x 300mm, 1 x 330mm. They are highlighted in yellow in the picture. Feed the hoses through the centre tunnel and through the frame at the rear.
Pic 7: Connect the two hoses to the pins as shown.
Pic 8: Fix the left side partition pieces 79A and 79B together with 2 x AM screws as shown.
Pic 9: Fit the curved part 79C in place as shown and fix with 2 x AM screws.
Pic 10: Repeat the assembly for the right partition using 79D, 79E and 79F and 4 x AM screws.
