Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,416 Points: 22,558 Location: Northamptonshire, England
Issue 63
The Upper Left Spider Leg Picture 1 show the parts for this issue Join the two parts together using a “P” screw with a washer as shown in pictures 2, 3, 4 and 5. Use the M4 Allen key.
Picture 6 shows the assembly complete for this issue.
Issue 64
The Upper Left Spider Leg Picture 1 show the parts for this issue On the inside of the first joint cover, fit one of the inner supports and secure it in place using 2 x type F screws, picture 2.
Retrieve the assembly from the previous issue and position the 4 holes of the first segment structure and secure it in place using 4 x type J screws with a washer on each one, picture 3. Now fit the cover and secure in place with a type J screw and washer, picture 4.
On the left side of the first joint, fit one of the side covers, so its hole fits over the hollow post on the joint as shown in picture 5. Fit one of the joint caps on the post and fix the parts using a type V screw, picture 6. Do the same on the other side of the joint, picture 7.
Take the assembly and join the end to the second joint, marked “B” using 2 x type J screws and washers as before, pictures 8 and 9.
On the inside of the second joint cover, fit one of the inner supports and secure it in place using 2 x type F screws, picture 10.
Fix the assembly to the second joint as shown in picture 11, using a type J screw with washer.
Picture 12 shows the assembly complete for this issue.
Issue 65
The Upper Left Spider Leg Picture 1 show the parts for this issue Take the long assembly from the previous issue and position the inner blue part as shown in picture 2. Place the other blue part the other side in the same way, then place the central blue part over the two side pieces and secure it in place using 6 x type E screws, picture 3. Once secure, place the three-cover plate over the screws. Note: The cover plates are numbered 1 -3, so make sure they are placed in order, picture 4.
At the open end of the second joint, fit the second segment structure. Use 3 x type J screws and 3 x washers to secure the two parts together, picture 5. Now fit the second joint cover securing it using 2 x type F screws, pictures 6 and 7. Turn the assembly over and place a type J screw plus a washer on place as shown in picture 8.
On the two sides of the second joint, push fit the two screw caps, picture 9.
In the recess on the underside of the third joint, fit the blue detail, pictures 10 and 11.
Position the third joint onto the end of the second segment and secure the two parts together using 3 x type J screws and 3 x washers, pictures 12 and 13.
Finally, fit the third joint cover as shown in pictures 14 and 15, using 3 x type J screws and 3 x washers.
Picture 16 shows the assembly complete for this issue.
