Issue 33
The Helmet and Chest Panel, Part 1
Picture 1 shows the contents of this issue. Retrieve the lightsaber and connect the circuit board as shown in picture 2. Fit the front hilt onto the end of the lightsaber, feeding the circuit board and wire through, picture 3. Pust the circuit board into the hilt as illustrated in picture 4.
Place a type A screw in place to secure the hilt in place, picture 5. Next, press the hilt plate until it clicks into position, picture 6. Do the same with the hilt button, picture 7.
Now fit the two front hilt decorations, picture 8. Place the front hilt decoration (B) as shown in picture 9.
Finally, place the other two decorations on the opposite side, picture 10.
That completes Part 1 of this assembly.
Issue 33
The Helmet and Chest Panel, Part 2
I would recommend taking your time with this section of the build as it is quite fiddly and you will need to make sure you have all the parts in the right orientation.
Retrieve the belt that came in issue 31. Slot the right belt box cover onto the strap as shown in picture 11. Note the hole to the right-hand side. Before fitting the control box, pass the cable through the rectangular hole in the strap, so the cable runs along the back of the belt towards the other holes in the belt. Secure the control box to the cover using 4 x type F screws, pictures 12 and 13.
Retrieve the belt buckle from issue 31 and the buckle box cover. Repeat the process as you did with the control box assembly. Picture 14 shows how the cables are placed before assembling the parts. Note: I would recommend marking the cables, so you know which cable is which on the final assembly. Again, secure the two parts using 4 x type F screws. You will need the spare screws that came in issue 31, pictures 15 and 16.
Fit the right box cable into the connector as shown in picture 17, then the buckle cable as illustrated in picture 18. Push fit the on/off switch into the slot on the box cover and feed the two cables through the hole at the same time, pictures 19 and 20. Secure the box and cover using 4 x type F screws.
Pictures 21, 22 and 23 show the assembly complete. Note: You do not test the circuit board at this stage.
That completes Part 2 of this assembly.
Issue 34
Picture 1 shows the contents of this issue. Retrieve the chest panel and press in the upper left decoration, picture 2. Place the right decoration on the opposite side, picture 3. Do the same with the lower decorations on both sides as shown in picture 4. Picture 5 shows the assembly complete.
Retrieve the helmet and place the left facial frame, the bag marked (34-07) into place, picture 6. Remove the protective film first. Take the internal temple cable to the left frame by fixing either end into the holes as illustrated in pictures 7 and 8.
Now do the same with the right facial frame, pictures 9 and 10. As before fit the internal temple cable in the same way as shown in pictures 11 and 12.
Finally, fit the two internal forehead connectors, making sure you have them the right way around, pictures 13 and 14.
Issue 35
The Helmet
Picture 1 shows the contents of this issue. Before you start the assembly, I would recommend leaving the parts in the bags until you come to assemble them as they have the number of the part written on the bag,
Retrieve the helmet and place the part 35-07 into the two holes as illustrated in picture 2. Picture 3 shows how the part looks when placed.
Do the same with part 35-03 in the two holes shown in pictures 4 and 5.
Repeat the process with part 34-04, attaching it the corresponding holes as illustrated in pictures 6 and 7.
Fit the central clip 35-08 to the underside of the crown clicking it into the two peds, holding together the three parts you have just assembled, picture 8.
Finally attach the decorative tube 35-08 as shown in picture 9, then attach the tube 34-06 on the opposite side as illustrated in picture 10.
That completes the assembly for this stage.
Issue 36
The Helmet and Left Hand
Picture 1 shows the contents of this issue. Retrieve the helmet you have been working on. Attach the left facial connector, this has two holes on the top of it. Place it into the two pegs as shown in picture 2. Do the same with the right facial connector, without holes, as illustrated in picture 3.
Instal the connector tubes from this issue and the two from the last issue. Picture 4 illustrates where all four tubes are connected inside the helmet.
Slide the friction spacer onto the base of the left thumb as shown in picture 5, then fit the lower joint, picture 6. Next, attach the right base of the left thumb, and secure in place using a type T screw, picture 7.
Slide the other friction spacer onto the peg on the right tip of the left thumb, picture 8. Attach the previous thumb assembly as shown in picture 9. Finally, attach the left tip and secure it in place using 2 x type T screws as illustrated in picture 10.
Issue 37 Part 1
The Left Hand
Picture 1 shows the contents of this issue. Slide one of the friction spacers over the peg of the index finger number 7, picture 2. Put the lower joint number 8 onto the same peg, picture 3, then cover it with the number 6 index finger securing it in place using a type “T” screw, picture 4. Do the same with the middle index finger parts 4, fitting it into the previous assembly and then covering it with part 5 and securing the assembly with a “T” screw as before, pictures 5, 6 and 7. Finish the index finger with parts 1, 2 and 2 x type “T” screws, pictures 8, 9 and 10.
That completes part 1 of the assembly for this stage.
Issue 37 Part 2
The Left Hand
As with the previous finger, slide one of the friction spacers over the peg of the left middle finger number 14, picture 11. Put the lower joint number 15 onto the same peg, picture 12, then cover it with the number 13 middle finger securing it in place using a type “T” screw, picture 13. Do the same with the left middle finger parts 12, fitting it into the previous assembly and then covering it with part 11 and securing the assembly with a “T” screw as before, pictures 14 and 15. Finish the middle finger with parts 9 and 10, securing the assembly in place using 2 x type “T” screws, picture 16.
Picture 17 shows the assembly stage complete for this issue.
Issue 38
The Left Hand
Picture 1 shows the contents of this issue. We continue with the left hand as we did in the previous issue. Slide one of the friction spacers over the peg of the ring finger number 7, then place the lower joint number 8 onto the same peg, picture 2. Cover over it with the number 6 ring finger securing it in place using a type “T” screw, picture 3. Do the same with the ring finger parts 4, fitting it into the previous assembly and then covering it with part 5 and securing the assembly with a “T” screw as before, picture 4. Finish the index finger with parts 1, 2 and a type “T” screw, picture 5.
As with the previous finger, slide one of the friction spacers over the peg of the left little finger number 14, and place the lower joint number 15 onto the same peg, picture 6. Cover it with the number 13 little finger securing it in place using a type “T” screw, picture 7. Do the same with the left little finger parts 12, fitting it into the previous assembly and then covering it with part 11 and securing the assembly with a “T” screw as before. Finish the middle finger with parts 9 and 10, securing the assembly in place using a type “T” screw, picture 8.
Picture 9 shows the assembly stage complete for this issue.
