Red Bull RB19 Official build. Stages 57 - 62 Options
#1 Posted : 15 April 2026 10:52:26
STAGE 57:
Rear right suspension 4.
Pic 1: Retrieve the assembly from the previous stage and locate the arm 57A.
It will fit in the backplate 55A where indicated.
Pic 2: Fit the parts together as shown and fix with 1 x S screw.
Pic 3: Fit the deflector 57B to the backplate, fitting the pins on the deflector into the holes on the backplate.
Fix with 1 x R screw from the other side.
Store the assembly safely.
#2 Posted : 17 April 2026 11:04:33
STAGE 58:
Rear right suspension 5.
Pic 1: Retrieve the assembly from the previous stage and locate the outer cover 58A.
The pins on the upper edge will locate in the holes on 55A where indicated.
Pic 2: Press-fit the part into place.
Pic 3: Store the assembly and unused part safely.
#3 Posted : 19 April 2026 11:44:03
STAGE 59:
Rear right suspension 6.
Pic 1: Locate the disc 59A and fit the hooked end of the outer strip 59C into the slot on the edge of the disc.
Pic 2: Wrap the strip around the disc and fold in the other end into the disc.
Pic 3: Locate the other disc part 59B.
It will press-fit onto the disc assembly.
Pic 4: Parts assembled.
Pic 5: Retrieve the assembly from the previous stage and fit the disc in place as shown.
Pic 6: Press-fit the hub 58B in place.
#4 Posted : 20 April 2026 15:57:48
STAGE 60:
Rear right suspension 7.
Pic 1: Retrieve the assembly from the previous stage and locate the caliper 60A.
Pic 2: Press-fit the caliper in place as shown.
Pic 3: Store the assembly and unused part safely for now.
#5 Posted : 21 April 2026 13:44:59
STAGE 61:
Rear right suspension 8.
Pic 1: Retrieve the assembly from the previous stage and locate the disc part 61B.
Pic 2: Peel the backing paper from the back of 61B and stick the disc to the surface of the brake disc as shown.
Pic 3: Store everything safely for now.
#6 Posted : 23 April 2026 10:21:59
STAGE 62:
Tyre rack.
Pic 1: Fit the wheel carriers 2 x 62C to the ends of the tyre rack 62A as shown and fix with 1 x KK screw in each.
The printed instructions have labelled the screws ā€˜E’.
Pic 2: Fit the wheels 2 x 62D in place as shown and press an axle 62E through the carriers.
Pic 3: Assemble the other side of the tyre rack in the same way.
Store safely for now.
This page was generated in 0.433 seconds.
