 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,860 Points: 17,732 Location: ipswich
STAGE 3:
Front wheel.
Pic 1: Fit the rim 3B into the tyre 3A. NOTE: The outside of the tyre has a bar code on it. (Highlighted) The outer rim fits on this side.
Pic 2: Fit the inner rim and fix the parts together with 4 x AM screws.
Pic 3: Store the wheel safely for now.roymattblack attached the following image(s):
STAGE 4:
Rear spoiler.
Pic 1: Locate the spoiler parts 4A and 4B. They will clip-fit together.
Pic 2: Parts assembled.
Pic 3: Locate the spoiler parts 4C and 4D. They will clip-fit together.
Pic 4: Parts assembled.
Pic 5: Fit the end plate 4E to the lower wing in the position shown. There are two locating pins on the end of the wing that will fit in two locating recesses on the end plate.
Pic 6: Fix from the outside with 3 x NM screws where indicated.
Pic 7: Fit the other end plate 4F in the same way, fixing with 3 x NM screws.
Pic 8: Slide the other wing 4C/D down between the end plates in the position shown. There are two locating pins on the ends of the wing that will fit in two locating recesses on the end plates.
Pic 9: Fix with 2 x NP screws where shown.
Pic 10: Fix the other side in the same way.
Store the assembly safely for now.roymattblack attached the following image(s):
STAGE 5:
Rear spoiler flaps.
It is suggested that you fit screws into all the holes in the end flaps and then remove them, to make assembly easier.
Pic 1: Retrieve the rear wing assembly and fit the lower flap 5A in place where shown. The tab in the centre of the flap will fit in the hole in the lower rear wing where indicated.
Pic 2: Fix from the outside using 2 x NP screws. Repeat on the other end plate.
Pic 3: Fit the flap 5D just above the flap 5A as shown and fix from the outside using 2 x NP screws. Repeat on the other end plate.
Pic 4: Locate the two white flaps 5B and 5C. They are easily identified as 5C has a ridge running along the top edge and the spacing of the holes in the ends is different.
Pic 5: Fit the flap 5B as shown and fix from the outside using 2 x NP screws. Repeat on the other end plate.
Pic 6: Fit the flap 5C as shown and fix from the outside using 2 x NP screws. Repeat on the other end plate.
Pic 7: Store safely for now.roymattblack attached the following image(s):
